Question about Logitech QuickCam Pro 5000 Webcam
A networkt error accurred while connecting to the server
Hii.. my name is kalim .. i'm using windows vista premium.. i have problem with the cam..the massages "a network error accured while connecting to the server" always appeared when i view my cam in YM.i tried to reinstalled the software and the YM but it didn't work..is there any advice for this problem i will greatfull appreciated ..thanks..
U must be running Nortons. Shut off your web browser intrusion and your outgoing email task and it will work. I had the same problem..Steve
Posted on Oct 29, 2007
SOURCE:
Windows Vista Home Premium update error Code 643
You will find a solution here:
(you can change language by changing "/en" to your language code!)
http://support.microsoft.com/kb/976982/en
Nov 21, 2013 | Microsoft Windows Vista Home Premium for...
Can vista home premium connect to a LAN
You should check the possibility to connect to homegroup network. I have Vista home OS and I can use router to connect to internet but I can not connect to other PC runned windows 7, I can see them but without connection. I had found on a forum that Vista home version can not interconnect in homegropu network.
Good luck with your search
Mar 19, 2010 | Computers & Internet
Hpqselsk.exe clr error 8004005 & cant open hp director
Its also known as .net framework. Its a software which few applications use for support like chat applications. Below is the system requirement for .net framework to work properly If your system does not fall under the category then you shall uninstall it.
  • upported Operating Systems: Windows 2000; Windows Server 2003 Service Pack 1 for Itanium-based Systems; Windows Server 2003 x64 editions; Windows Server 2008 Datacenter; Windows Server 2008 Enterprise; Windows Server 2008 for Itanium-based Systems; Windows Server 2008 Standard; Windows Vista Business; Windows Vista Enterprise; Windows Vista Home Basic; Windows Vista Home Premium; Windows Vista Starter; Windows Vista Ultimate; Windows XP; Windows XP Professional x64 Edition
Jul 26, 2009 | Office Equipment & Supplies
Sending mail with Vista Windows Mail
Window Vista also have Outlook Express.. please enter the full info for your email account..
On the E-mail Settings page, enter your email account information as follows:
Your Name
Enter your first and last name.
E-mail Address
Enter your email address.
Account Type
Select POP3.
Incoming mail server
Type for your incoming mail server.
Outgoing mail server (SMTP)
Type for your outgoing mail server.
User Name
Enter your email address again.
Password
Enter the password you created for your email account.
After this please check for "Test Account setting"
If everything is working fine, then remove the previous account
And let us know the error message if come up any.
I hope it will resolve the problem and you will be able to use the Outlook.
May 01, 2009 | Microsoft Computers & Internet
Hii,i am having windows vista ultimate
You can follow this instruction: http://m0001.gamecopyworld.com/games/pc_brian_lara_international_cricket_2007.shtml
P.S.: If this information was helpful, please rate this solution.
Mar 13, 2009 | Microsoft Windows Vista Home Premium with...
Unable to check for updates with Windows Vista Home Premiun, SP1, 32 bits, error code 80244019 for Windiws Update and 0x80244019 for Windows Defender, last update instaled Jan/01/09
I've been having the same error when I try to run Windows update on a Vista Ultimate machine setup for use with our SBS 2003 server running ISA 2004.
The Solution that I found is this.
When you setup Vista for use with a domain it creates the following regkey with a subkey etc ( policy ) that sets Vista to look for a WSUS server.
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate]
"WUServer"="http://serversbs"
"WUStatusServer"="http://serversbs"
[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\AU]
"NoAutoUpdate"=dword:00000000
"AUOptions"=dword:00000004
"ScheduledInstallDay"=dword:00000000
"ScheduledInstallTime"=dword:00000003
"NoAutoRebootWithLoggedOnUsers"=dword:00000001
"RescheduleWaitTime"=dword:00000001
"UseWUServer"=dword:00000001
When I deleted this key and rebooted my PC windows update was working.
Hope this was somehow usefull
source: http://www.vistax64.com/vista-general/3421-windows-update-error-code-80244019-a.html
Good luck
Feb 23, 2009 | Microsoft Windows Vista Home Premium with...
Server certificate
When an SSL certificate is created, the address that will be used to connect to the web page is specified. (www.mywebpage.com) If you are connecting to the IP address of the website, it will tell you that the addres that you have gone to, and the site on teh certificate don't match. There are also some problems with forwarding domain names improperly. what address are you trying to go to, and what exactly does the error say? I have a DI-614, and have never had a problem getting to Secure sites.
Feb 10, 2009 | Microsoft Windows Vista Ultimate Edition
Chating problem
Make sure your router isn't blocking the ports for it.
Oct 04, 2008 | HP Compaq Presario v3000z Notebook
Windows Vista home + Windows XP Professional Networking issue
Make sure domain settings to your server are correct on the notebook computer. These settings are located in the control panel of the system setting.
Whats the operating system of your server?
Make sure the firewall in windows security is turned off too. Sometimes that thing sneaks up on you.
I haven't used the home edition of Vista but another reason why it might not be working is because it isn't the business version. Microsoft might have added extra security to prevent the home version from connecting to a server. I know we use the business version of Vista at work and it is working that way on the intranet server without a problem.
I would check with Microsofts website on that.
Jun 21, 2008 | Microsoft Windows XP Professional for PC
System State not successfully
This is common in the following OS.
• Microsoft Windows Server 2003, Web Edition • Microsoft Windows Server 2003, Standard Edition (32-bit x86) • Microsoft Windows Server 2003, Enterprise Edition (32-bit x86) • Microsoft Windows Server 2003, Enterprise x64 Edition • Microsoft Windows Small Business Server 2003 Premium Edition
This problem occurs when the following conditions are true: • You back up data from a volume that contains a Microsoft SQL Server database. • The recovery model of the SQL Server database is configured to use an option that is different from Simple.
Submit a request here to get a hotfix from Microsoft ( Its free and no product key will be asked )
http://go.microsoft.com/?linkid=6294451
Feb 18, 2008 | Microsoft Windows Server Standard 2003 for...
Logitech QuickCam Pro 5000 Webcam Logo
43 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Damen Wong
Damen Wong
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
