Question about Amana AER5515QA Electric Kitchen Range
Oven temp won't go up
Oven temp won't go past 230
Ge profile JPB90W S2WW convection self cleaning
They do charge a fortune for parts. Get the part number for the controller and then log it into ebay. Often you can get the parts there for a much better price. Otherwise repair will not be cost effective unless the part is dirt cheap. Yeah, right!
Sep 15, 2017 | GE Ovens
GE wall oven gas model # JGRS14 won't heat past 100 and I don't see any flames
if you can see the ignitor glowing on either the broiler or the lower area of the oven then the gas valve is bad and not opening anymore,sometimes the ignitors are the culprit as they are in series with the gas valve and if weak wont let the valve open,but both upper and lower burners not operating i would suspect a gas valve first
Nov 24, 2012 | GE JGRS14 Gas Single Oven
My oven won't go past 350 degrees
If you have multiple elements it is possible that one may be burned out and limiting the high end of operation.. Check all to make sure that none is open and replace as necessary.
Check attached site for parts and prices. If you can get the part number it is possible for you to be able to get it on ebay for less money. No harm in checking. Search Over 2 1 Million Appliance Parts
Aug 31, 2017 | Ovens
Kenmorw built-in oven (Model #30129) won't maintain cooking temp, flame is off and on continously, take twice as long to bake or broil food. If the temp is set for 500, the oven temp might be 250.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Aug 06, 2011 | Ovens
Bottom oven will not heat up past 230 degrees
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 15, 2011 | Maytag Gemini 30" Self-Cleaning...
No sure if the temp. is in C or F
Most ovens are now calibrated to read the temp in C.
If you are not sure which is which on your oven, then if it is centigrade, it will go up to about 230 c on the dial, or 400 to 500f in farenhiet
Jan 01, 2011 | Ovens
When using the BAKE setting, the desired temperature is input and the oven begins a preheating phase. The temp will only rise to one degree less than the desired setting, and the oven never reaches the...
more than likely there is an issue with one of the temp sensors. you will need to press and hold clear then upper on off at the same time then release them then immed. press clear 3 times and hold on the 3rd till the service screen appears. on the right side you will see internal temp and catalyst temp they should be equal or very close. ill bet one of them is alot higher than the other if so the sensor will need replace but depends which one is bad as there are 2 of them. if the problem is on the lower just repeat above but use lower instead of upper
Dec 07, 2010 | Miele H398BP2 / H398B2 Electric Double...
How to change bulb on newworld g90 vision cooker
To change the bulb is quite easy, the glass lens screws off, give it a good soak and clean whist popping out to buy a new bulb, otherwise you won't notice the difference. Note the bulb is a special oven bulb, if yoo can't read the old bulbs rating it's probabily a 25W 230/240V rated for 300deg C - try Wilko's around £2.50
Sep 18, 2010 | New World G90m Gas Double Oven
Amana AER5515QA Electric Kitchen Range Logo
15 people viewed this question
Top Amana Kitchen Ranges Experts
Sal De
Ismael Rodriguez...
Paul Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
