Question about Kenmore Oasis HE 27082 Top Load Washer
F68 error Does anyone know what the F 68 error is? On most cycles it stops sfter a few seconds and flashes F1. If I srop and start it does the load fine. On some sycles it doesn't stop at all. I did the 3 sec thing and the error that comes up os F 68 Thanks
  • anniewhite Nov 16, 2007
    My washer is about 3 months old and am trying to wash clothes and Fl keeps comeing up. What is that?
  • 3 Answers
The F1 code(60-68) means primary control failure. The treatment for this problem is to replace the primary control panel. It is very easy to replace. Here is my story, I had the F50 code appear and my machine would not drain or spin a load of clothes. My machine was only 7 months old thus still under warranty. I called for service and they came in 2 days, I watched as the repairman popped the top of the machine up. He used a screwdriver that he placed in the crevice on the front of the machine, just below the lid. Inside the machine, he pulled out a book. I asked if he took that out of my machine, he hesitantly said "yes" and then told me that every machine has a service book in it. It has a list of codes and gives the serviceman step by step instructions. He ordered parts and rescheduled another service date. Well the service date was this morning, however I had not yet received the parts for the repair. This made me very upset that I once again had to schedule another date a week later. OK, mind you I have not done laundry in 2 1/2 weeks. The part came tonight and I took it upon myself to fix the damn machine myself because I am stubborn like that. IT WORKS!!!!!!!!!! Who needs a repairman, my husband thought I was joking that I was going to fix it myself. Good Luck!!!
Posted on Nov 22, 2007
LOL, I opened mine and YES it was there.
Posted on Sep 02, 2008
What is code F1 mean on the Whilrpool Cabrio. The washer stops about 5 seconds when I first put it on.
Ok the Cabrios have alot of problems. In your owners manual there is a big page where it gives you errors codes and what to do it also givees you a diagnostic feature which helps determine the problem. This site gives you the fault codes and what to replace. F1 means primary control failure. Also sometimes when the control board is bad something else could also be wrong. Good Luck
F1 (F60-68)
Primary Control Failure F then 1 flashes when there is a primary control failure. Replace the machine control assembly.
See Accessing & Removing the Electronic Assemblies. F1 (F60-68)
See Accessing & Removing the Electronic Assemblies.http://www.advantagesupplyfl.com/WhirlpoolCabrioWasherFaultCodes.html
Jun 02, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My whirlpool cabrio washing machine keeps giving me an F1 ERROR when it goes to the rinse cycle. It will complete the wash after i hit cancel reset and wash. Any ideas?
F1(F68)-Pressure Signal Out-of-Range
I telephoned Whirlpool at 1-800-253-1301. Whirlpool acknowledged the F1 fault and will send a serviceman, free parts and labor, to correct the problem concerning the "famous" F1 fault. This is even for washers out of warranty! This concerns model WTW6600SW2 washers. Be sure to get the authorization code from them so the service person cannot argue about costs.
Jan 05, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a Whirlpool Cabrio top load washer. When I load the clothes and start the washer and it begins to run I hear an alarm, it stops and a F1 flashes on the display. What does this mean?
F1 (F60-68)
F1 flashing on the display indicates a primary control failure.
"F then 1 flashes when there is a primary control failure. Replace the machine control assembly."
The link below lists Cabrio failre codes.
Dec 16, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Error f1 flashes after just a few seconds of turning on the wash cycle. if i turn off power and try to start again it will somtimes start if not i turn off and try again sometimes it takes 3 or 4 times to...
The Whirlpool Cabrio and Kenmore Oasis (same machine) are infamous for this problem. Depending on the serial number you may be entitled to a new control board installed for free under a recall program. Call Whirlpool for eligibility. I had just had mine replaced last week for free and it runs fine now.
Apr 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 error code
check the FixYa website for other solutions for your model, look for one with 29 postings........
Feb 21, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 error code on Kenmore Oasis He
I think there might be a recall on your washer call to see. I am not for sure that there is a recall but I a m pretty sure there is. So don't quote me on that. the f1 error code usually means that you have a bad board. f1 means that your pressure switch line is failing and this is all in your board. check your owners manual if whirlpool is not going to pay for this repair sometimes there are extended warranties in your manual
May 29, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Moister can get in between the contacts,is it in a high moister environment? Try using a hair dryer on the panel to dry it out.Also unplug it to reset.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 31, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
F1 error code
The F1 error code indicates a primary control failure or pressure signal out of range. Once the pressure hose & air dome have passed testing, the control board will need replaced. Good Luck And Please Rate FixYa!
Dec 20, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
How do you open a Kenmore Elite Oasis top-loading washer?
I just finished installing my new control unit for my Kenmore Oasis and my F1 problems are GONE! I ordered it from Sears Direct Parts. With shipping and taxes it came out to about $174 for the part, but our issues are gone and now we can wash a load of clothes without having to reset it several times.
Mar 18, 2008 | Washing Machines
F1
jenkle, F then 1 flashes when there is a primary control failure. There is a couple of things you can try. 1. Unplug the machine for 2 minutes and see if the error returns. If it does, try activating the auto diagnostic mode. With the washer plugged in and all indicator lights off, select any key except power, start and stop. Here's what you do; press/hold for 3 seconds, release for 3 seconds, press/hold for 3 seconds, release for 3 seconds, press and hold for 3 seconds. If you did it right all indicators will light and 88 will appear in the display. If there are any faults, they will then display, look for a F-60 through 68. This will confirm the board is corrupt. If no faults are found the machine will go through a five minute automatic test cycle. To stop the test, just press stop/cancel. Check your owners manual and see how long the board is warranteed. Catriver
Sep 02, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
708 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
