Question about Apple iPod nano
Battery My ipod 4 gb silver does not seem to hold a charge and now won't even turn on connected to computer to say charging. Is the lithium battery gone , how and where do i replace it. Thanks
  • Anonymous May 10, 2008
    the battery will not hold a charge!
    Novelist:
    Champion:
  • 382 Answers
Http://www.ipodjuice.com/?gclid=CKWNzPufs48CFSasGgodp1dqSg
The battery is flat, replace it for less than $30. Easy if youre good with your hands, if not- go to your nearest Apple store.
Posted on Oct 29, 2007
Why isnt my ipod charging?
iPod's battery doesn't charge
Several things could keep your iPod's battery from charging. The major causes are listed below in logical order. Check each one to see if it's what's keeping your battery from charging.
Low-powered USB port
iPods that connect to USB ports require a high-power USB port.
Keyboards and some USB hubs will not charge iPod. Connect iPod directly to the computer or to a USB AC power adapter. Click here for more information.
Connect directly to computer
If you connect iPod to something that connects to the computer (like a USB hub or FireWire drive), connect iPod directly to the USB or
FireWire port on the computer.
FireWire port on a Windows PC
The FireWire (IEEE 1394) ports on some Windows-compatible computers may not be powered, and consequently won't charge iPod when you plug it in. Check here to see if the FireWire port on your PC can charge iPod.
Your computer goes to sleep
Your computer can only charge iPod when it's turned on and not asleep. Make sure your computer is on and not set to go to sleep when you want to charge iPod. Tip:
Some Macintosh computers can charge iPod even though they're asleep.
If your sleeping computer doesn't charge iPod, don't worry, just wake it and let iPod charge.
hope this helps
Aug 14, 2012 | Apple iPod touch
My ipod will not turn on
Find out what to do if your iPod won't turn on.
Several things could prevent iPod from turning on. Check each cause in this order to find out what's wrong.
Products Affected
iPod
Resolution
Make sure the Hold switch is off
1. Check to see if the Hold switch is on. It's located on the top or the bottom of iPod. When it's in the on position, you'll see an orange patch.
2. To turn the hold switch off, slide it until you no longer see the orange patch.
3. Press any button to turn on iPod.
iPod hold switch on iPod hold switch on
Make sure the battery is charged
iPod won't turn on if the battery is empty. Instead, a low battery screen appears for about 3 seconds when you try to turn it on.
iPod battery empty icon
To charge your iPod, connect your iPod to your computer's built-in 6-pin FireWire or high-powered USB port or connect it to the Apple iPod Power Adapter and plug the power adapter into an electrical outlet. Note: iPod models without a Click Wheel cannot be charged via USB. iPod shuffle requires a high-power USB port to charge. iPod nano and iPod (5th generation) can charge via USB or FireWire, but they require USB to sync with iTunes. If you're not sure what iPod model you have, click here.
If you are connecting via USB and the battery is completely discharged, there may be up to a 30-minute delay before iPod powers up. Click here for more information.
Reset iPod
If iPod still does not turn on or appears to be "frozen" you may need to reset it. When you reset iPod all your songs and files are saved. Some customized settings may be lost.
Let the iPod battery drain
In rare cases, iPod might get into a state in which it needs to be drained completely before it can be reset. If iPod didn't turn on after you reset it, follow these steps:
1. Disconnect iPod from all power sources and leave it disconnected for about 24 hours.
2. Reconnect iPod to the Apple iPod Power Adapter or computer and reset it.
Update iPod's software
If iPod turns on after you reset it, use the latest version of iTunes to update iPod.
Additional Information
If you have tried the solutions above and iPod still won't turn on, check the following:
* Make sure iPod is the only device in your FireWire or USB chain. Disconnect everything but the mouse, keyboard, and your iPod, then see if it will turn on.
* Make sure you are using the FireWire or USB cable that came with your iPod, and that the cable is in good condition.
* Try connecting iPod to the built-in port of a different computer to see if that works. Note: If using a portable computer, make sure it is plugged in to a power source and that the lid or display is open. If the lid is closed the computer may go into either standby, sleep, or hibernation mode and iPod will not charge properly.
If you still can't turn iPod on after performing these steps, it may need to be repaired. You can arrange for repair at the iPod Service Website.
iPod may not power on, may be stuck on the battery logo, or may have stopped responding while playing music (in which case the Click Wheel doesn't respond).
Products Affected
iPod classic (120GB), iPod nano, iPod classic, iPod classic 160GB (Late 2009), iPod (5th generation), iPod (5th generation Late 2006)
Resolution
If you experience any of the above issues, try the following steps:
1. Toggle the Hold switch. To do this, slide the switch to Hold (an orange bar appears) and then slide it back (orange bar is hidden).
2. Reset the iPod by holding down the Menu and Center buttons for 10 seconds.
* If the Apple logo appears on the display, connect the iPod to a computer and verify that it appears in iTunes and can play music. If the iPod appears in iTunes and can play music, no further troubleshooting is needed.
* If the Apple logo does not appear or the iPod is not seen in iTunes, connect the iPod to a power source by either plugging it into an Apple iPod USB Power Adapter or directly into a computer's USB port.
3. Let the iPod charge for at least 20 minutes. Note: If the iPod is connected to a computer, make sure the computer does not sleep, standby, or hibernate during the 20-minute charging period.
4. After the iPod has charged for at least 20 minutes and while it is still connected to the power source, toggle the Hold switch again as in step 1.
5. Try resetting the iPod by holding down the Menu and Center buttons for 10 seconds.
* If the Apple logo does not appear or the iPod is not seen in iTunes, try putting the iPod into disk mode and restoring.
6. Try putting the iPod into disk mode.
* While in disk mode, connect the iPod to iTunes and try to restore.
* If the iPod is still not recognized by iTunes, the iPod should be serviced.
See http://www.apple.com/support/ipod/ and click the Service tab for more information about your service options.
Hope it helped...
May 21, 2011 | Sony NWZ-E436F MP3 Player
My ipod wont charge
There are only three possible causes of the problem for the iPod that's not charging.
1. Dead battery
2. Loose connection
3. Bad charging cable
* First, you may want to try to use another cable then try to charge your iPod. Or you may try to connect it to different USB ports of the computer and see if the same problem will occur.
If that did not help, then you need to send the iPod to the manufacturer and have them check the battery and possible loose wire connection inside.
Thank you and good luck!
Jul 31, 2010 | Apple iPod shuffle Second Gen. Silver (1...
My ipod wont seem to hold a charge
What generation iPod? iPod batteries, like all other lithium ion batteries, will go bad after they have reached their maximum charge cycle limit. If this is an older model iPod, the battery most likely needs replaced. Roughly 50 dollars for most models.
Jan 06, 2010 | Apple iPod nano
My ipod nano wont charge and wont turn on.
Sounds like a bad battery. You can get replacement batteries here http://www.ifixit.com/iPod-Parts/iPod-Nano
-=/ Daft Tech /=-
Oct 21, 2009 | Apple iPod shuffle Second Gen. Silver (1...
My ipod shuffle 2nd generation won't turn on and I don't know if the charger even works. My computer won't read my ipod shuffle or notice it.
http://www.apple.com/support/ipod/five_rs/
If this doesn't fix it, and it's over a year old, and you don't have an AppleCare Protection Plan... Recycle it, because man, it's gone.
BTW: The unit charges off of a standard USB port. Double check the connection and USB cable for defects and try another computer and USB cable.
-=/ MLF /=-
Oct 20, 2009 | Apple iPod shuffle Second Gen. Silver (1...
Not showing any indication$any function
Does your iPod do anything when you connect it to the computer? Does your computer see it? Ipods generally will not respond unless they have a charged battery. Try to charge it, connect it to the computer. If it will not charge, it probably needs a new battery. There are a number of places that can do that for you. Hope that helps.
Dec 05, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Ipod nano 8gb Mp3
It might be possible the you left your iPod playing overnight when you stopped using it. The batteries might be drained already and will need some time in the dock for it to be charged for the batteries to warm up and start charging again. Please ensure that the connections are not loose also.
Oct 21, 2008 | Apple iPod shuffle Second Gen. Silver (1...
My Ipod Nano Wont Charge on the wall Charger.
Hello Kawase,
I would suggest you try charging the unit this one time by connecting it to the computer. I suspect that the charger may be defective if plugging the wall charger into the iPod has no effect on the low battery warning. If the iPod is able to be charged from the USB port on your computer that would tend to confirm that the charger is not working. If the iPod does not charge when connected to either the computer or the wall charger then you may very well have a another defective iPod.
Best Regards
Ken
"Go Ahead. Use Us."
Jun 30, 2008 | Apple iPod nano 3rd Generation
Apple iPod nano Logo
52 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
