Question about GE GSH22JFR Side by Side Refrigerator
GE Refrigerator side by side loose door handles
How do you tighten loose door handles.
  • 2 more comments
  • Anonymous Dec 08, 2007
    the door handle on a kenmore bottom freezer refrigerator will not pull up, is ther another way to take it off. I tried to jerk it up but lifted the door off
  • idirago17 Jan 10, 2009
    The bootom portion of the handle is loose.
  • Anonymous Mar 17, 2014
    I would like to know what tool I need to tighten the loose door handle on my freezer door
  • Anonymous Mar 26, 2014
    how do you get to the screws to tighten door handle
  • 30 Answers
I was actually trying to find a solution to this problem myself though I'm pretty sure I already know the solution. Try this: grip the handle that's loose firmly and jerk it up. The handle should come up and the straight out to reveal the spring clip mechanism holding the handle on. Tighten the screws on this and then put the handle back on by pushing it towards the fridge and jerking it down. You make want to protect the fridge above and below were the handle attaches so you don't scratch the fridge door when pulling the handle on or off.
Posted on Oct 30, 2007
  • Tyler T Nov 14, 2007
    If my last post didn't help you the fridge you have is different than I thought. If there are trim pieces above and/or below your handles they will have to be removed to tighten the handles. You just have to push the trim pieces up (or down if it's the lower one) with a flat blade screwdriver or putty knife. The handle screws should then be exposed so they can be tightened. If the holes are stripped you can fill them with glue (polyurethane glue works well) then let it dry and use the same or some coarse threaded screws.
  • 15 Answers
SOURCE: door handle is loose on model#gsh22jftacc. how do you tighten?
If it's the same as the one we have (which is similar to the pic posted on yours) there's a plastic piece on the top and bottom of the handle that you have to pry up (gently) to get to them.
It looks like a line that runs horizontal across the handle, but it should come up with a little force (meaning it shouldn't require tools). You have to pry it from the side, not the top or bottom.
Posted on Mar 03, 2009
SOURCE: GE Adora Side by Side Loose Handle
The cover plate comes off to exposed the screw that needs tightening. My husband just fixed ours as I was looking up how to fix it.
Posted on May 06, 2009
SOURCE: Ge profile refrigerator door handle is loose
On the GE Profile, the handle is mounted to two small screws. To detach the plastic housing, you must press on the two connection points (the base and top of the handles) and slide the handle up or down (takes some effort). The handle will come off and you will have very easy access to these 10mm screws.
Posted on Apr 09, 2008
SOURCE: The handle on my refrigerator door (Admiral side
There is a plastic card that came with the refrigerator. Pull the handle towards you and slide the card between the door and handle on the top side of the lower handle. Slide the card until it stops, I believe its 11/16". Next slide the handle upward to release it. It may take some force to release the handle. Once its removed, you will see a bracket on the handle. In my case, the screws were loose. Tighten the screws and replace the handle and its fixed. To reinstall the handle, line up the handle with the brackets on the door. Slide down until you here a click that indicates that the handle is installed properly.
Posted on Dec 30, 2009
guru_fixya
  • 944 Answers
SOURCE: i have a ge side by side refrigerator model
1. off the upper and lower ends with flat plastic or apadded flat head screw driver so as not to scratch your stainless steel. Atwisting wrist action will suffice. 2. Now the screws are exposed, you can re-tighten them. 3. Replace the plastic covers starting with the base whichhas a small plastic the goes into a slot in the main handle. Then glide therest forward and it snaps in effortlessly.
http://www.partselect.com/Schematics/GE/00115279i01.gif
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Jan 02, 2011
Door handle is loose, how can i tighten it?
Might have to remove the inner panels to tighten the handle inside the door .
Remove the inner linings toget access to the inside of the door .
Sep 28, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
One handle is loose-how can I tighten it
shoulb be screws under cap on handle remove and tighten that should do the trick
Aug 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Loose door handle
I just FINALLY fixed mine...  Popped little cover pieces off top and bottom of handle with a plastic bread bag tag slid along space created by loose handle (did not scratch finish on door).  That exposed the screws which could be tightened with a phillips screw driver; the cover pieces then snap back on the ends of the handle.
Apr 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
How to fix loose door handle on GE model DSF25KGTB BG side by sid
If the screws aren't obvious, they will be locater under a pop out plug on under a nameplate on the handle.
Feb 20, 2009 | GE GSS20IEP Side by Side Refrigerator
do the covers pop off to tighten screws on the handles
Oct 21, 2008 | GE Adora (DSF25KGTBG) Side by Side...
Loose door handle
If a tight place is worn out, then try warmer temperature and go to the tools store to place the door with your new tools.
Aug 08, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Loose handle on door
grab hold and pull straight up!! itll be tight but just pressured on, theres an mounting screw under there, then just pull back down and on
Feb 25, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Loose handles - GE monogram model # ZFSB25DMD SS
try removing the handle, that will expose the mounts for the handle. You should be able to tighten them after removing the handle.
Jan 08, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Door Handle repair
The fastner must be loose. Remove both set screws remove your handel. Then tighten the fastner. reinstall the handel and tighten your set screws. let me kniow if this helps
Aug 18, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
GE GSH22JFR Side by Side Refrigerator Logo
1,677 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
