need the model number but most Zeniths require resetting the lamp life counter when the lamp is replaced. But I will need the model number to assist you further with the issue.
The lamp time reset will be or should be in the owner manual---Google the model number with keywords "lamp install" with the model number and the "manual" with the model number---Google can be a great help.
Hi, If it is Sony Grand WEGA KDF-55XS955 tv then it needs lamp replacement as existing lamp in tv has reached at end of its working hours life and causing this problem. If lamp in tv has not been replaced in last 2-3 years then it is time to replace it. Lamp replacement procedure is easy and written in user manual. Required lamp part number for tv is as follows: A1085447A ....
LAMP BLOCK ASSY XL2200U Available in Sony Accessories Store for $200 Please buy Sony original lamp for good picture in tv. Let me know if you have additional question. Thanks.
you can fix by replaced your tv lamp only.mostly lamp number menstion on top side.
if not found then tell service center only model number of your tv and get your Lamp.
Lamp replacement way menstion in Lamp user manual.
I'm not sure what is brand and model number of your tv but lamp light On shows its dlp tv. If lamp light is lit that means lamp inside tv is dead/ broken and need to be replaced. Replace lamp in tv to get it back in business and usually lamp replacement procedure is easy and written in related user manual.
Call Encompass electronics 1-800-638-3328 also part # is on Tube you have a RED/GREEN/Blue each tube has part number on it.UNless you have DLP TV then it would be a Lamp.
Please replace lamp in TV and lamp replacement procedure is written in user manual of TV. Please buy Sony original lamp for your TV and avoid aftermarket / cheap lamps.
Need further info, let me know with model number of Sony TV.
Call Optoma technical support listed on the optomatv website. They will ask for the set serial number. Based on the serial number, they will tell you which replacement lamp is the correct model for your TV. (I found this out after ordering the wrong replacement lamp based simply on the model number of my TV and finding that it did not fit.)
The TV should "blink" a number of times after it fails to start up (the red light blinks a certain number, pauses, blinks a certain number, pauses, etc.). This tell what is wrong with the TV. If the LAMP light is what is blinking, then the lamp needs to be replaced.
Most of the problems with this television are related to the lamp or lamp chamber. If the Television lamp is burned out or worn, or the lamp will not start, then it will not try to come on. There are circumstances where the LAMP light on the front of the TV will not come on, even though the lamp is out. I would try replacing the lamp (which is meant to be user-replaceable). The popping noise you heard could have been the lamp going out.
The lamp chamber door also activates a switch that tells the TV that the door is in place. This switch will sometimes go bad, showing a relatively small amount of resistance, but enough to fool the TV into thinking that the door has not been replaced, causing the TV to shutdown. Make sure that the lamp door is properly replaced if you do remove it. It is no longer available from Sony (too many warped doors from heat damage).
Lamp part number is available in the user manual, as well as instruction on changing it.
