2003 Toyota Tundra, put 12v car charger in to charge phone and radio and clock went out. Replaced fuse labeled for clock but nothing.
SOURCE: radio not working
there is a fuse box under the hood by the driver side front strut tower. there is also another one under the dash by the steering shaft
SOURCE: 2006 Toyota Matrix 2nd fuse panel location?
The second fuse panel that you seek is under the dashboard, on the driver side (for a US car). This box is called the "JB1" (junction block #1), and contains several relays in addition to the 15 amp "CIG" fuse that you need to replace.
Hope this helps, and thanks for choosing FixYa!
Happy Thanksgiving!
SOURCE: 1990 toyota 4runner
most of the things you mention comes under acessories so try the fuse and it should be a 20 amp yelow fuse
SOURCE: 2003 Toyota Echo radio/clock not working.
Disconnect your negative battery cable for about 10min. After you re-connect, the stereo should reset itself and start functioning. Best of luck!
Greg
SOURCE: 2003 Toyota corolla A/C compressor not coming on fuse good, A/C charged, no pwer at compressor
it is located in the engine compartment fuse / junction box it is on the drivers side then cover to the box will show you witch one it is ( the relay will be white in color)
