Moultrie Game Spy D555i Trail Camera Logo
Larry Martin Posted on Mar 02, 2014
Menu screen nothing but lines.
Hi. Right from the start my menu screen was unreadable. Camera will not operate, and now the screen won't even come on. The memory card is good, as well as the batteries. Any way to reset?
  • Larry Martin
    Larry Martin Mar 14, 2014
    Hi Everyone. I am pleased to report that the camera is working fine now. And am ashamed to report what the problem was. I bought TWO separate packs of Duracells dated 2024. When the camera didn't work, I replaced the (fresh) batteries with other fresh ones. I assumed they were good because I had just purchased them AND because of the date. But...it turns out that BOTH packs were totally dead. My voltmeter wasn't handy, so I didn't check them. I still find it unbelievable that new Duracells could be bad. I put in store brand alkalines and all worked perfectly. What's that lesson about NEVER assume? I appreciate all your comments and help. What a great group!!
A
Anonymous
Turn camera off, remove battery's and sd card. With everything out turn it to the on position for about 2-3. After 2-3 minutes put batterys back in while on the on position. Once he says no card or no memory turn the camera off put sd card back in and test the camera.
Samsung TV vertical lines
Hi Paul,
I am sorry. There is nothing you can do about it. It appears to be a defective panel.
The menu screen is on and we can not take pictures, we can not get out of that setting
Hi, If it won't let you quit out of the menu screen I'd suggest turning the camera off then on, if that doesn't work take the battery out for a couple of minute and that should do the trick.
I have the pearl blackberry, on my bbm its showing that i have unread messages but when i go to click on them theres nothing there.
There may be an unread email somewhere in your inbox. If you click the menu button when in the mail section there is a "mark all unread messages read (or something similar)." This should clear up your unread message count on your "Today" screen.
Best Regards,
Bill
3helpful
SONY Digital Camera DSC-W50 doesn't work. Lens goes in and out...
Hi!
Please try the under given troubleshootings:
(i) Please check if the Battery is fully charged.
(ii) Next, turn off the Camera, remove the Battery pack then press and hold the Power button for 30 seconds.
(iii) Then, reinsert the Battery pack and turn ON the Camera.
(iv) Next, try to access the menu options either by directly pressing the menu buttons or while reviewing the images.
(v) If the menu options are accessible while reviewing the captured images then reset the Camera to the original factory settings.
Please follow the steps given below to reset the Camera to the original factory settings:
(a) Turn ON the Camera.
(b) Access the menu screen either by directly pressing the Menu button or pressing the menu button while reviewing the captured images.
(c) If menu screen is accessible, then press the right arrow on the Control button to select (Setup) Settings, then press the right arrow again.
(d) Next, select the Setup 1 option by using left/right/up/down arrow on the control button.
(e) Then, select Initialize and OK.
(f) Finally, follow the on-screen instructions to set the clock in the Camera.
Performing the above steps will reset the Camera to the original factory settings. If the issue persists even after performing all the above steps successfully then the issue is related to hardware malfunctioning and service is required.
Please feel free to contact for further information or any clarification.
2helpful
When i turn on my camera the lens goes in and out but it wont let
Hello!
First, check if the Battery inserted in the Camera is fully charged. If not then charge the Battery to its fullest then insert it in the Camera to check its operation.
Next, remove the Battery from the Camera then press and hold the Power button for 30 seconds. Then, reinsert the Battery pack in the Camera and turn it ON and check its operation.
Finally, please check if the menu screen is accessible by pressing the menu button directly or while reviewing the captured images. If the menu screen is accessible then reset the Camera to the original factory settings.
Perform the steps given below to reset the Camera to the original factory settings:
(a) Please press the menu button directly or while reviewing the images to access the menu screen.
(b) Then, press the right arrow on the control button to select Setup option.
(c) Next, use left/right/up/down arrow on the control button to select "Setup 1" option.
(d) Then, select the "Initialize" and OK.
(e) Finally, follow the on-screen instructions to set the clock on the Camera.
performing all the above steps will reset the Camera to the original factory settings.
If, even after performing all the above steps, the issue persists then the issue is related to hardware malfunctioning and service will be required.
D40X: can't access menu with card in camera
Try "Custom Settings Menu" -> "06 No memory card?".
Does it have any influence?
Tom
6helpful
Cant get onto the menu screen
I finally figured it out!!! There is a button on the right-hand side of the camera, which switches it from normal mode to simple mode. Just press the button and everything goes back to the way it was...
Screen Adjustment
On your monitor at the bottom there is 3 buttons. The one all the way to the left is the "menu" button. The next one (going right) is the "NEGATIVE" button. The next one (going right) is the "POSITIVE" button.
You can move your screen around. First, start by pressing the menu button.Then, a menu in blue, with a bunch of little white icons will appear. Next, go over two icons by pressing the positive button twice. Then, proceed to push in the "menu" button again. A bar will appear. By pressing your negative button, your screen will move left. Pressing your positive button will make your screen move right. Adjust your screen until the black on both sides are of even proportion. Then, press the menu button to return to the orginal menu you started at. Proceed to press your positive button two more times. Then, press your menu button. Then, once again, use your positive button, and your negative button to adjust your screen to even out the black on the top and bottom.
Top Moultrie Video Cameras Experts
ADMIN Andrew
ADMIN Andrew
Stan Ford
Are you a Moultrie Video Camera Expert? Answer questions, earn points and help others
