could be a setting in image settings there are a number of picture affects to choose from i.e sepia,negative,color tints etc, should be in picture editor
Do a factory reset to this set, and check. Refer its user manual for details. On some occasions, you might have to enter its service mode option to do a factory reset. If you wish to know more about how to enter, adjust and exit the service mode, check this link. It has details about how to enter service mode to many brands of TVs. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in thebrand name and model number to of your set, to its search box, and
press 'Enter' or view it in Mosaic / Timeslide
option.
To unlock a Samsung SGH-A877 Impression phone:
1. Dial *#06# on your phone to get the IMEI or serial number.
2. Write down the serial number.
3. Contact MObile Operator Customer Service Department. Another option is you could also visit a website that offers an online Subsudy Unlock service. (charges may apply)
4. Set your device in portait mode.
5. Hit "Dial" button.
6. Type #7465625*638* and the unique 8-digit unlock code given to you.
7. If you entered everything correctly, the device will show: "Network Lock Deactivated".
When this machine was started after connecting the Color Image Reader-E1/F1, the screen for the shutdown sequence appeared (and E732-9999 was recorded as an error history in service mode). When the main power switch was turned OFF/ON by following the instruction on the screen, the error code "E732-8888" was displayed. When connecting the Color Image Reader-E1/F1, follow the field remedy below. - E732-9999 is recorded when a printer model detects a scanner for the first time. (This is not an error code but an alert.) - E732-8888 can be displayed when a different scanner is connected to this machine.
1. Connect the Color Image Reader to this machine. (Do not connect the DDI cable). 2. Turn ON the main power switch. 3. Change the setting values of the following service mode items. - Service mode > COPIER > Option > BODY > W/SCNR: from '0' to '1'. - Service mode > COPIER > Option > BODY > SCANTYPE: from '1' to '0'. Reference: For the Color Image Reader-E1/F1, this mode has to be set to '0'. On the other hand, it has to be set to '1' for the Duplex Color Image Reader-G1. - Color Image Reader-E1: Platen cover model - Duplex Color Image Reader-F1: Two-sided reversal reading type ADF model (DADF-M1) - Duplex Color Image Reader-G1: Two-sided simultaneous reading type ADF model (DADF-T1: only for the iRC5180) 4. Turn OFF the main power switch, and connect the DDI cable. 5. Turn the main power switch ON. Note: How to turn OFF the main power switch. When turning off the main power switch, be sure to follow the steps below to protect the HDD inside this machine. 1. Hold down the control panel switch for 3 sec or more. 2. Following the instruction displayed on the shutdown screen, operate the control panel. (The main power switch is turned OFF automatically.) 3. If there is a need to unplug the power cord (from the wall outlet), perform step1 and 2 above before unplugging it.
There is a manual focus adjustment above and between the red and green gun, located in the front of the TV behind the panel; It is a small black box about 3X3" . This has all three adjustments .
Try the code below at your own risk. I will not be liable for any damage this may cause to your phone.
Type the following codes on standby menu
*#0206*8378#
after typing you will be presented to a Test Mode menu Select H/W Test Select Audio Settings Select IIS Normal (option 10) this is the normal volume for the phone. Scroll down to select Rx vol. then change level 14 to a higher value. Maximum is 30,000, i set mine at 5000 You can do the same for IIS Normal2 this is the volume for Music Player
edge enhancement option i think would be enabled if you are in dynamic or movie mode. What it does is to enhance the contrast of the edges of 2 different colors.
I have the LA32S8, similar specs but only 7000:1 CONTRAST ratio. when playing dvd, i set it to movie mode. Settings vary on different tv and player. you can adjust first the backlight, then brightness then contrast, color and sharpness. the brightness you adjust by choosing the level that shows enough details on dark scenes. adjust if its too dark not to see the details of the scene. contrast, you can set by distiguishing vivid colors of the picture, dont put too much contrast as your picture would look flat. it should have a 3d look, same also with sharpness, you can experiment on the face of a person to show details on the edges.
color you set just enough to make it accurate on color reproduction.
My settings for movie are
contrast 92
brightness 49
sharpness 23
color 57
tint g48 r52
backlight 7
tone warm1
digital NR off
black adjust high
dynamic ocntrast high
gamma +2
edge enhancement on
color space auto
