Computers & Internet Logo
abany ambiri Posted on Mar 02, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Manually eject cd
How to open the cd drive
jav mora
Level 2:
Champion:
  • Expert 220 Answers
  • Posted on Mar 03, 2014
 jav mora
Expert
Level 2:
Champion:
Answers
220
Questions
0
Helped
47724
Points
350
On the cd drive there should be a small hole right next to the eject bottom use a paper clip stick it in the small hole push in twice the cd drive will eject
1 Related Answer
Anonymous
  • 3278 Answers
  • Posted on Jun 12, 2009
SOURCE: My cd/dvd drive is not working.
You could reinstall the CD/DVD drive software, but it sounds like the CD/DVD drive is faulty. You'll need to replace the drive.
How to open cd tray on acer Aspire E1-522-5603
If this is a windows 7 install, have you tried going to Windows Explorer, then right click on the drive that represents your CD drive, and see if there is an "Eject" option. Otherwise on many newer CD drives, there is a very small hole next to the eject button. To open it manually stick a paper clip into the hole right next to the eject button. There will be a little resistance because this is a manual release to open it.
1helpful
DX4300-150
CD/DVD Drive Tray problems
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
My MSI GT660 Dvd will not open or eject
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD disc.
My dvd tray is not ejecting,i cannot insert a cd
CD Drive Tray problems
There are two ways to open the CD drive door if the button just below the drive tray does not work.
If this does not work then you can manually open the CD drive tray by -
If you still having problem opening with the Eject button, then the CD drive is faulty and needs replacing.
Help LITE-ON DVDRWSHW-1635S door wont open on Gateway computer
There are two ways toopen the CD drive door if the button just below the drive tray does not work.
Straighten a paper clip and gently insert it into a tiny hole below the drivetray next to the Eject button. Push the paper clip gently until the drive traypops out, then pull the tray until it is fully out, then you can remove the CDdisc.
If you continue having problem opening with the Eject button, then the CD driveis faulty and needs replacing.
2answers
I have a burned CD in the CD drawer and I can't retreive it, I can't find the button to open the door. Somewhere there is a button" OPEN DOOR" but I can't locate it.
If you continue having problem openning with the Eject button, then the CD drive may be faulty and needs replacing.
1helpful
3answers
Dell Studio 17 Stuck Disc in drive
if you look close infront of the cd-dvd playerdoor there is a little hole if you stick a paper clip in there it will eject it.
1helpful
The CD ROM Drive is not ejecting properly
hi,
Locking device / software installed
First, verify no locking software is being loaded, which would allow the CD-ROM tray not to open. If you are unable to determine this, reboot the computer and as it is booting up, attempt to eject the tray. No power to computer or CD-ROM drive
If you have recently installed a new CD-ROM drive or you have moved the computer, it is possible that the power to the CD-ROM may have become loose or disconnected. Check the cable connections. Bad eject button
If you are running Microsoft Windows 95, Windows 98, Windows NT 4.0, Windows 2000, Windows ME, or Windows XP, open My computer, right-click on the CD-ROM drive and choose the option to eject. If this ejects your CD-ROM drive tray, it is likely that the button on the CD-ROM drive has become defective and it is recommended that the drive be replaced. CD stuck within drive
It is possible that a CD may have become stuck within the CD-ROM drive. If the CD-ROM drive has a small hole (that is not the head phone jack), using a paper clip, place the paper clip within the hole and attempt to manually eject the CD-ROM tray. If the CD-ROM drive is only partially able to be opened, attempt to pull the tray gently to see if it can be manually ejected. If it cannot be opened any further, it is likely that the gears within the CD-ROM drive have become bad, dislodged, or that a CD is positioned in the drive, which does not allow it to open. Incompatibility with IDE / ATAPI interface
If you have an IBM compatible computer and recently installed the CD-ROM drive and are unable to open the drive, attempt to temporarily disconnect the IDE cable to verify that you not experiencing an issue with an incompatibility between the CD-ROM and motherboard. Once the IDE cable has been disconnected, power on the computer and see if the CD-ROM drive tray is now able to be opened. If the drive is able to be opened with the IDE / ATAPI cable disconnected, it is recommended you use the interface card supplied with the CD-ROM drive or the ATAPI interface on the sound card / motherboard. Bad drive
Unfortunately, if after following the above recommendations you are still unable to properly open the CD-ROM drive using the button on the front of the CD-ROM drive, it is likely defective and should be replaced. Caution: If you are able to open the CD-ROM drive using a paper clip. We do not recommend that you continue using the CD-ROM drive by manually ejecting the CD-ROM using a paper clip. The drive should be replaced and this is not meant to be used as a temporary solution. Additional information and tips for buying a new CD-ROM drive can be found on our CD-ROM buying tips section.
21helpful
2answers
CD driver stuck
In the front side of the dvd drive you will see a small hole ...so to eject that cd put one niddle in that hole and .
Now press the button at just after that apply a force on niddle .suddenly you will notice that cd will come outside ,if not try more times and you will learn to eject the cd when you are unable to do it by pressing the eject button...
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi
Technical Associate
2answers
DVD stuck in drive
try ejecting through my computer then right clicking on the drive and select eject or there should be a little pin hole at the front of the drive to push and force a manual ejection
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
