The control panel service light is blinking and the error code rotates between 24 and 40. temps are 18 and 38
This error code is a long compressor run time for the freezer compartment, check the condenser to make sure its clean. Also make sure al fans are running as needed. You may need a service person if all these items are functional, as a leak in the sealed system can also cause this issue but rare to have this in both compartments.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
SOURCE: Sub Zero 680 freezer temperature problem
check the condencer on top .open the doors look up you should see three screws take them out and pull down the panel and clean the condencer if its clean CALL repair guy!
SOURCE: Service light is blinking & code 06 EC flashes on Sub Zero 650
Turned the breaker off to the fridge for 15 minutes and turned it back on.
SOURCE: The control panel flashes
"EC 50" means excessive refrigerator compressor run time. What is the serial number? Is the condenser fan running? Can you feel airflow from the left side up top? Is the strip between the fridge and freezer hot to the touch?
SOURCE: sub zero ref 690 s model with error code ec 50
EC code is on with a flashing service light . Is this a problem that I can fix on my own?
SOURCE: Sub Zero Model 680 - Light in Fridge and Control Panel out
Try wiggling light switch side to side kinda hard, (the light switch is the one on the left) it should come on, showing you its a bad lt. switch.if that fails install 1 new 40watt,(long) appliance bulb. but it is going to be the switch or the bulb considering there wasn't any wiring work done on unit. part# for the light switch is 3060140 make sure the back of the switch is white not black (black is a fan switch) Good Luck !!!
