Question about Radio Communications
Uniden # bc145xl scanner
When turned on the volume ia good after about 10 or 15 minites it gets low and sounds scractchy. please help thanks
  • 3 more comments
  • Anonymous Nov 18, 2007
    Need instructios for how to program BC 145 XL
  • Anonymous Jan 01, 2008
    how to program my scanner
  • rlj08 Jul 16, 2008
    my bc145xl has low audio all the time just looking for some pointers
  • gary koser
    gary koser Nov 10, 2008
    i have a unidenbearcat bc 145xl 16 channel programable and lost how to program it thank you!
  • sarahs1486 Apr 29, 2009
    I have the bearcat bc 145xl and I dont know how to program it.
Hi my uniden bc145xl has just lost sound it still scanns fine just no sound is there a fuse or somthing to replace because when it quite there was smoke coming out the ext. sp hole
Posted on Feb 20, 2010
  • stlplayer Sep 28, 2010
    TBA820 IC, 56 ohm B resistor need to be replaced. The IC
    overheats as a result of a leaky or shorted 47 uf electrolytic cap to the
    right of the IC, Just repaired mine tonight. The parts can be ordered
    from Mouser Electronics
    Ron
How do I program my Uniden Bearcat BC 145xl? I lost the booklet.....
Posted on Feb 03, 2008
E bay has the book for this model
Posted on Feb 19, 2008
Select Station by manuel button then put in frequency and push E for enter then press manuel again to proceed to the next station and your done. Only takes up to 400 meg Hz. Get an 800 meg Hz converter to get 800. then put 4 in place of the 8 to
program.
Posted on Jan 08, 2008
Uniden scanner bc145xl will not turn on. its plugged into a good power strip
Reset power button on power strip first turn off then on.If that don't work check and see if it is a switched outlet turn wall switches on in area.check and make sure cord is secured to scanner. Plug a lamp that is on in the strip this will help you when you are trying to turn switches on by yourself you can see it light up.
Sep 20, 2017 | Uniden Radio Communications
BC145xl. Where can I get frequencies?
Here's how to program;
How do you program Uniden Bearcat bc145xl
Go to this site and you'll see a U.S.map. Click on your state, then after click on your county and a list of freq's will be there for you.
https://www.radioreference.com/apps/db
Aug 31, 2015 | Uniden Radio Communications
Why won't my BC145XL scan
push manual on the scanner push manual again to see if the channel changes if so then push the scan button , if still no scan see if the volume is turned up. if not turn it up and see if you have any white noise , if you have what is called white noise turn the squelch till the noise is gone then press scan if it still does not scan you may have all the channels locked out and if so they need to be unlocked refer to the manual to know how to unlock channels then try again if that does not work scanner may need to be repaired
Jul 02, 2014 | Uniden BC350C Base Scanner
I have a uniden bearcat bc145xl 16 channel scanning radio, every time I push the manual button, and try to put in a code I can't get all the frequency numbers put in. I don't know what I am doing w
When you press the manual button and then enter numbers it thinks you are entering channel numbers not frequencies.
Try manual button and then prog button.
Then enter the frequencies.
Hope this helps
Aug 18, 2017 | Radio Communications
How do I program my bc145xl scanner
I searched but could not find a manual for the BC145XL. Your keyboard looks identical to the UBC144XL though, so the instructions for it should work on your scanner. You can download the manual for the 144 here:
http://www.scribd.com/doc/2056189/UBC144XLT
Bill B
Feb 19, 2010 | Uniden BC244CLT Base Scanner
Cant get programed
Programming the BC350 is fairly straight forward, and the operating manual has very good step-by-step instructions. You can download and print the manual by following the link below. The programming instructions are detailed on pages 24 through 28.
http://www.uniden.com/pdf/BC350Com.pdf
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Dec 31, 2009 | Uniden BC350C Base Scanner
I have a bc145xl and i dont know how to put in my frequency channels i got
I couldn't locate a manual for you, but the 16-channel BC145XL is a fairly typical Uniden scanner.
Turn the scanner power ON.
Press the MANUAL button to stop scanning.
Press the MANUAL button repeatedly to advance to the channel that you wish to program.
Enter the frequency that you wish to program, including the decimal point. Frequency range of your scanner is 29-54, 136-174, and 406-512MHz.
Press E (Enter) to cpmlete the process.
To continue programming, press MANUAL to advance to the next channel, and start the steps again.
Dec 09, 2009 | Uniden BC350C Base Scanner
Lost book to scanner its a uniden bearcat bc145xl 16 channel and dont know how to program it.please help
do you have a button marked "prgm"
if not, then push the manual button until it
gets to the channel you want to program,
then enter the freq ie... 155.xxx and hit
enter, don't forget the decimal point .
http://www.uniden.com/index/manuals_results.cfm?cat=3
heres a link to uniden bearcat manuals , but i don't see yours .
but my instructions will get the job done .
Jan 13, 2009 | Radio Communications
Help please
how do i program it
Oct 23, 2007 | Uniden BC244CLT Base Scanner
Radio Communications Logo
2,338 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
