Cars & Trucks Logo
J
James French Posted on Mar 02, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Spitting sputtering I have a 88 civic that spits and sputters at first take off and thin clears out what is the problem
Louis
Level 2:
New Friend:
  • Expert 66 Answers
  • Posted on Mar 02, 2014
Louis
Expert
Level 2:
New Friend:
Answers
66
Questions
0
Helped
18059
Points
149
Throttle position sensor, if it has one. Oxygen sensor if it has one or choke positioner.
5 Related Answers
Anonymous
  • 291 Answers
  • Posted on May 15, 2008
SOURCE: engine spits and sputters
check your spark plug wires.
Anonymous
  • Posted on Feb 09, 2009
SOURCE: car spits and sputters
engine spitutters,has no power and dies when i stop but will idle just fine
Anonymous
  • Posted on Apr 28, 2009
SOURCE: spits and sputter on 1/4 tank of gas
My brothers 97 silverado did the same thing. He replaced the fuel pump and the problem stopped.
Anonymous
  • 31 Answers
  • Posted on Apr 29, 2009
SOURCE: spits and sputters only at low rpms
electrical issus. have you ever replaced the spark plugs and wires? distributer cap and rotor? might be time to do this routine maintenence.
Anonymous
  • 4 Answers
  • Posted on May 23, 2009
SOURCE: eng. shakes spits/sputters oil in spark plugs
I just had this fixed on my suby today. The cause is that the spark plugs, go through the valve covers on the 2.5 l .When the o rings in the cover go, the result is oil in the spark plugs. The cost of the repair in Canada was about $500 including diagnostics as well as new plugs and wires About 1.5 hours labor and new seals and gaskets. It now runs like new. This is a common problem for this subaru engine as well as for the dodge neon.
2002 buick lesabre spits sputters voltage jumps
check you have good earthing points, also check the earthing strap from engine to shell. main earthing point follow the negative lead it will go to the shell.
1helpful
3answers
When advancing down highway vehecle spits and sputters then clears up then spits and sputters what is it
When was last tune up? Plugs, wires, all filters & fluids? Especially fuel filter. I'd start there and run a good fuel system cleaner through it.
Spits and sputters in damp weather until it warms up
Sounds like ignition problem, check all electrical connectors in ignition system for tight corrosion free connections, check condition of plug wires and distributor cap.
1995 Jeep grand cherokee is missing while running. When it is under a heavy load (driving fast) it runs fine. When idleing and slow driving it spits and sputters.
I have the same problem on my 95 grand cherokee laredo. Sometimes it starts out fine and after about 10 miles it starts spitting and sputtering. Then after a while it seems to clean out and run fine again for a little while. Then other times it starts out spitting and sputtering at the begining. I changed the fuel filter and that was not it. It is a 4.0L 6cyc. Any Ideas?
Thanks,
Broken Arrow, OK
1helpful
3answers
Engine spits and sputters
Top Honda Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Honda Expert? Answer questions, earn points and help others
