Question about Nikon F80 35mm SLR Camera
N80 camera I have an N80 35mm camera that shows an ERR message when I try to use it. I have checked th manual and don't know what to do. Any suggestions?
  • Anonymous Dec 30, 2008
    my camera says err and wont let me do anything with it. I have never had this problem before, all of my lenses have always worked and my F stop is set right
First, make sure that your lens is an AF lens (MF lenses won't meter with your camera). Next, be sure that the lens aperture ring is set to the smallest f-stop (highest number...usually f22 or f32). If something else is going on try to give some more detail.
Posted on Nov 03, 2007
SOURCE:
I bought new batteries for my N65 and my camera keeps blinking ERR.
The manual mentions only 2 conditions where the Err message appears. First if it is Err + E at the same time, the film has not completely wound and needs to be reloaded.
If it is Err alone, the manual states to fire the shutter and see if the message remains. If it does, to contact a Nikon Authorized Service Rep.
Jun 23, 2011 | Nikon N65 35mm SLR Camera
I have the same problem. An N70 with the err message. If the rewind buttons are pressed (without any film in the camera) the camera tries to rewind but will only stop if the back is opened. I tried...
The Err message alone indicates that a malfunction has been detected, and the manual recommends to fire the shutter and check for the message to clear. If it does not, to contact a Nikon Service Rep.
If it is Err + E, the film did not advance properly and needs to be reloaded.
May 03, 2011 | Nikon N70 35mm SLR Camera
Just recieived a used Nikon N80 and it gives the message of open door.Frame counter and film indicator flashes when door is shut and no film is in in camera?
Confirm tht DX shows in LCD. If not then press and hold shift button then press ISO so "DX" appears.Open Camera Back. Insert film cartridge, pull film leader out to right and align with red index mark (inside film chamber on right). Make sure there is no slack in leader.Close camera back until lock release snaps closed. Fully depress shutter until film advances to first frame.
Confirm " 1" and film transport show in LCD. If Film is not loaded correctly, "ERR" show on LCD. Open cack and reload film.
Users manual can be downloaded from:
http://www.lensinc.net/manuals/Nikon_N6006L.pdf
Nov 03, 2010 | Nikon N80 35mm SLR Camera
Err message nikon f-100
Read pages 99-101 of the manual. There are numerous err messages referenced. Some blink others only have the E of Err blink and the like, all with different solutions. If you cannot find the manual call Nikon Film 1-800-645-6687.
Aug 10, 2010 | Nikon F100 35mm SLR Camera
When camera is turned on Err show on the screen.
The 'Err' message comes from the lens. Check to see that the aperture ring is correctly set on your lens.
Feb 03, 2010 | Nikon N50 35mm SLR Camera
Error msg
Hello!
Southern Photo Technical Service is a Authorized Service Center for NIKON.
You have a shutter failure!!
We do service the camera model you mentioned and the standard cost to Clean, Lube, Repair and Adjust all functions to meet manufacturers
specifications is $169.00 plus return shipping.
All repairs have a SIX MONTH WARRANTY!
Include a copy of this reply and
receive a 5% INTERNET discount on your repair!!
Bring it in, or
Pack your equipment securely and insure it properly.
Send it to:
37 NE 167th Street
N. Miami Beach, Florida 33162
305-653-7355
May 28, 2009 | Nikon N80 35mm SLR Camera
'Err' & 'E"
Is the film loaded correctly? Have you tried reloading it? Also is it flashing DX too? That would mean the film speed is not DX coded so you need to set the film speed manually.
Sep 23, 2008 | Nikon N80 35mm SLR Camera
Error message on camera
I had the same problem, what I did was set ISO to manual,and still got the Err,but I took a shot and the film advanced and it seems to be ok now.
Mar 25, 2008 | Nikon N80 35mm SLR Camera
ERR message
unmount and remount the lens. Make sure you have the aperture ring on the lens set at the minimum f-stop number, ie f22, f32. There should be a small tab on the lens to lock the aperture ring in that position
Dec 27, 2007 | Nikon N80 35mm SLR Camera
Nikon F80 35mm SLR Camera Logo
206 people viewed this question
Top Nikon Photography Experts
Ric Donato
pictureman4u
Jay Plesset
Are you a Nikon Photography Expert? Answer questions, earn points and help others
