Question about Frigidaire FGF376 Gas Kitchen Range
Frigidaire Gas Range Oven not getting hot - FGF376CEFP
My oven does nor get hot now.  When "preheat" is selected, the temperature only gets to 240 or so.  Thats it.
Model # FGF376CEFP - Frigidaire Gas Range
Any help is appreciated!!!
  • wjacob1200 Mar 16, 2009
    the oven will not come on. I can see the glow plug and after a while smell gas.Pre-heat will only get up to 230.
    Problem Solver:
  • 9 Answers
DEAR CORDLESS TRY CHANGEING THE GLOW IGNITER THE GLOW IGNITER GOES BAD AFTER A FEW YEARS AND YOU HAVE TO CHANGE THEM YOUR BURNER SHOULD LIGHT IN 30 TO 60 SECONDS IF YOUR GLOW IGNITER IS NOT DRAWING ENOUGH AMPS YOU WILL SMELL GAS BUT NOT IGNIGHT THANKS GEORGE
Posted on Apr 11, 2009
My gas oven will not get hot. for a couple of months, it would only warm up at 375 degrees, but not it will not heat at all, however the preheat button does come on. the last time i tried it, it smelled of...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Aug 13, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
I dont know the exact model but its a kenmore gas range...it displays EO -F3- when i try yo preheat the oven...it is not getting hot at all
Hi
Thanks for using FixYa. Error E0-F3 means oven temperature sensor failure and to resolve this the oven temperature sensor should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 20, 2010 | Kenmore 46133 Stainless Steel Dual Fuel...
Oven won't get up to temperature
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has failed...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 14, 2010 | Frigidaire Gallery 30" Self-Cleaning...
Frigidaire gas range broiler element does not light.
glow plug needs to draw 4 amps to open gas valve even if it red hot ...not drawing 4 amps replace glow plug
Aug 22, 2009 | Kitchen Ranges
My professional series oven preheats and then stops heating.
HI, there may be some issues within the dual safety gas valves. they mat be malfunctioning. these valves control the gas flow and if the shut prematurely, it will disrupt the heating process. You could also have a sensor issue as well but, im sensing that this abnormal shutdown is being cuased by a fualty Dual oven safety valve assembly.
Please rate and god bless:)
Apr 15, 2009 | Frigidaire GLGF386DC Stainless Steel Gas...
KitchenAid gas range superba not reaching/registering right temp.
Always preheat your oven and let it cycle at least 2 times. Your unit may show 350 but the manufactures know that it is not 350. When it registers preheated, it really means that it is at an acceptable temperature to start cooking. If you think that it may not be calibrated correctly, your owner's manual will have instructions on how to recalibrate your oven. You will be able to raise or lower the temperature by + 25 degrees or - 25 degrees. As far as the gas smell, you will from time to time smell a gas smell with a gas oven especially if you are right at it when it ignites. If you are smelling gas when it is not in use then you should be extremely concerned.
Mar 14, 2009 | KitchenAid KGST307 Gas Kitchen Range
Preheat gets to temp but oven drops 20 d+/- after food goes in. Is this normal
You may have already solved this but either your convection motor is not on or you have an air leak. I would get the repair man out since it is probablt still under warranty.
Oct 24, 2008 | Frigidaire PLCS389DC Dual Fuel (Electric...
Oven doesn't heat
sounds like you have a bad oven ignitor, although oyu see it glowing orange its not hot enought hoopen the gas valve, very common occorance. 2 maybe 4 screws and 2 wires, order aand replace the bake ignitor
Mar 26, 2008 | Kitchen Ranges
Temperature is Unstable
erratic temp in oven can also be a bad oven ignitor, usually to low of a temp and not able to stay at temp, too long to preheat.replace the bake ignitor
Mar 11, 2008 | Hotpoint RGB745 Gas Kitchen Range
Frigidaire FGF376 Gas Kitchen Range Logo
579 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
