Question about Garmin StreetPilot i3 GPS Receiver
Replacement Memory Battery
Where do I purchase the "Internal Memory Battery" of an older (1999) Garmin GPS III Plus unit ?. OR what is the technical description and specification of the battery ??. Does any one (other than Garmin) have circuit digrams for the unit ???
  • 1 more comment
  • Anonymous Nov 04, 2007
    How I can install a new battery.
  • Anonymous Nov 12, 2007
    I have the same problem with my Garmin GPS II Plus. The unit requires a new internal battery.
  • PeterFixYa Mar 09, 2009
    March 2009 I replaced the solder type battery of my GPS III Plus with a battery holder (clip) that a “Basic CR or BR2032 Coin type battery”, without solder connections, will clip into. Replacement batteries can be purchased at less than a $1.00 of E-Bay, free post ex Hong Kong.
  • 1,606 Answers
The Garmin GPS III and III plus use a tabbed lithium coin battery. Its is a Panasonic BR-2032. You can buy these for about $2 from larger electronic suppliers. The problem is that the shipping or minimum order will make that $2 battery cost you about $25. For you cheap guys there is a solution. You buy a CP-2032 and a coin holder. $2-3 for the battery and $1-$2 for the holder. 6 screws to open the case, cut the wires close to the battery as possible. Solder the wires to the coin holder (good idea to heat shrink or cover the solder joints), put in the new battery and you are done the easy bit. You will most likely have to trim away some of the plastic on the holder such as legs or other things sticking out. Unfortunately you can't really do this with out fitting it in the case and you don't want to do that until you have the holder on the wires so it will be in the right place. Once you get that, simply play with it until you can put the screws back in. And tighten gently. Not too much or the gasket will be squeezed too far out. Put tAA'sx AA's back in, take it outside so it has an unobstructed view of the sky, set it down and go for a long coffee or three. It will now download the almanac and any other data which can take 15 minutes or more depending on the satellites. You should see a low battery error and other errors such as saved data lost. Ignore these. You can put it on a external power plug or just leave it off with the AA's and in 5-7 days it will have reset the error as it figures it it now charged. You get the battery error even with a new fresh charged battery. I think there is a Garmin reset code to force this but none of the codes I have tried have worked.
Posted on Nov 13, 2008
  • 3 Answers
I dont have a GPS 111 plus unit but my guess is that it has a very small solder in 3v rechargeable lithium battery (as do most Garmin units)
This is a $1 quick and dirty fix which I have used for the i2, i3 and i5 series and could probably be adapted for the GPS111.
Forget all about the 'special' battery, just get a CR2025 or similar 3v lithium button cell. make it 'wire ended' by baring off the ends of some very thin connecting wire say 2 inches long and tape to each side of the battery with insulating tape. Slacken the 3 screws holding the AA battery pack and tuck the CR2025 underneath, pack some sponge on top so that when the screws are re-tightened there is sufficient pressure to keep the battery firmly in place and also to keep the wires held firmly against the battery. Remove the original button cell and wire in the new CR2025 make sure you keep the same polarity. Thats it.
I know the CR2025 is not chargeable but it does not need to be, its capacity is about 100 times greater than than the original cell and it will last at least 5 years without becoming discharged, it is not affected by the tiny charge current the garmin tries to put in it. The original button cell will have failed within about 5 yrs so it's a 'no brainer'. This solution is intended for folks with some electronic knowledge and ability, If you do not fully understand any of the above then dont attempt it'
Hope this helps.
Posted on May 23, 2008
Batteries+ was not able to do it. It is a small button type battery that is soldered in place. I am going to unsolder mine and see if I can read the numbers on the battery. I am then going to get a battery holder with leads, and solder it in place. I'll let you know what happens.
Posted on Nov 26, 2007
    Novelist:
  • 233 Answers
Do you have a "Batteries +" store in your town?
They can 'build' any battery from parts.
Posted on Nov 01, 2007
Hey Guys,
What about rechargeable batteries seen here:
http://rechargeable.minamoto.com/ion-****.html
Would it be a good solution?
Posted on Aug 01, 2008
SOURCE:
How can i get a replacement memory battery for garmin gps-75?
FDK ML621 TZ1 Battery
Garmin GPS Internal Battery
The link above has info on the battery replacement. You can do a search for the battery using the battery number.
May 29, 2014 | Garmin GPS
Car charger not charging internal battery ..gtm 20 cord ...nuvi 755
There is a fuse in the car charger adapter silver tip.... Unscrew it CAEFULLY its spring loaded and check fuse
Nov 06, 2010 | Garmin nuvi 755T Car GPS Receiver
Have a garmin gps3 that will not power up - batteries checked OK. gps hasn't been used for a couple of years. replaced batteries with new - no go
IF it stil won't pwer up with the dc plug, I suspect the internal battery. Lots of info online on replacement, you can CAREFULLY snip one lead as a a diagnostic test to take it out of the circuit. Good Luck!
Sep 07, 2009 | Garmin GPS III
Garmin GPS III plus- ROM failed message
Try leaving it on for a few days on cig lighter with unit ON. gps III plus has a rechargeable valadium battery soldered to the board on the inside of the unit to hold memory of your waypoints.You can solder a new one in for about 5 buks-it may need a new one but try charging it first
Jan 27, 2009 | Garmin GPS III Plus GPS Receiver
Internal Battery Low
Same problem. Remove the 8 screws, unsolder the battery from the circuit board, pry off leads, place electrical tape around edge of new battery, solder on the leads, solder leades on circuit board. Remember which side was up before soldier, close unit, you should be good to go.
Aug 14, 2008 | Garmin GPSMAP 180 GPS Receiver
Garmin gps III / internal battery replacement
March 2009 I replaced the solder type battery of my GPS III Plus with a battery holder (clip) that a “Basic CR or BR2032 Coin type battery”, without solder connections, that is, they simply clip into place. Replacement batteries can be purchased at less than a $1.00 of E-Bay.
Jul 07, 2008 | Garmin GPS
Acquiring satellites
Garmin has a history of internal rechargeable battery problems that go back at least as far as the GPS III Plus. There is a button cell battery in the GPS III that is used to help it "remember" where to search for satellites (according to their tech department). It was supposed to have a 10 year life, but mine failed after 6 and they would not repair the unit. The unit would eventually operate, but as soon as power was turned off, it would lose all routes, waypoints, etc. That is not my idea of a good deal.
The 276C has a similar problem; if you leave it off of the charger for more than a day or so, the MAIN battery is fine, but the unit will not find satellites. There is a software fix for this if you have an older unit but it really doesnt fix it; the fix simply forces the unit into a mode that says "STORED WITHOUT BATTERIES" which is a misnomer; my batteries were in and charged, but I think what they meant is - the internal battery bit it.
If you reset the unit by holding the POWER button and the ZOOM OUT BUTTON at the same time, the entry screen will pop up. Accept the conditions and the unit will attempt to power up. I have had mixed success with this technique. The BEST technique is to LEAVE THE UNIT ON THE CHARGER at all times when it is not in use!!!!
Also go to their site and make sure that you have the latest software 5.4 and save your waypoints, tracks, etc., before you download the new software.
Mr. EE PE
Jun 23, 2008 | Garmin GPS
Garmin 180
You need to replace the internal Battery with the Panasonic BR2032-1F2 battery. However, yes your waypoints will most likely get lost when you do this.
May 07, 2008 | Garmin GPSMAP 180 GPS Receiver
Garmin 48 memory loss
I have fixed several Memory battery low for the Garmin 48 .
May 30, 2007 | Garmin GPS 48 GPS Receiver
Garmin StreetPilot i3 GPS Receiver Logo
3,454 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
