Manual can be found here:
http://veronaappliances.com/sites/default/files/documents/verona/vebig24-operation_installation.pdf
Thank you for your post, Chrissie!
I understand that your Frigidaire duel fuel oven is not heating properly. I see that you have replaced your temperature sensor and heating elements and your oven is still not working. This could be a possible issue with your control panel or wiring harness. Since it could be anyone of these underlying issues I would recommend having a professional technician out. This will help you avoid any unnecessary part purchases. Hopefully this is helpful information. -Matt
Thank you for your inquiry, Bego?a Rebolledo-Kaufman!
From the information you have provided you are experiencing an issue with your Frigidaire double oven not heating. It sounds like a possible problem with your element or thermostat. I would suggest to perform a reset on your range, to see if that would help correct any miscommunication within the electrical components. In order to reset your range you would need to flip the household circuit breaker off for ten minutes. If you still continue to have an issue with the oven I would recommend having a professional technician out to provide an accurate diagnosis and replace any electrical parts needed inside of your oven. Hopefully this is helpful to some degree. -Matt
