Question about Samsung Blackjack SGH-I607 Smartphone
I can't get my blackjack phone off of vibration
Somehow my blackjack got on vibrate.  I have gone to settings, sounds, ringtones and tired 10 times to change from vibrate to a ringtone.  It will not change.  I have changed my phone many times and never had this problem.
  • 1 more comment
  • yadayadaya Dec 01, 2007
    I have the exact same problem. When I click any of the other ring profiles, it won't change.
  • Anonymous Dec 01, 2007
    I have the same problem. Everytime I go to settings to change it it says "settings could not be opened"
  • Anonymous Dec 29, 2008
    same problem and no solution
Press the # for few seconds to toggle between vibrate and ring
Posted on Sep 04, 2008
What you do is go to profiles and go to edit then u can change the settings
Posted on Aug 21, 2008
Ringtone to be set in iPhone
Ringtones can be set for the whole phone in Settings-->Sounds-->Ringtone.
You can set a ringtone for each of your contacts by editing the contact in the Phone app or the Contacts app. When you touch the "Edit" button when viewing any individual contact, you can assign a specific ringtone and vibration, and text tone and vibration, to that contact.
Sep 01, 2014 | Apple iPhone Cell Phones
Tracfone customer service
  1. Check a ringer volume and profile. Press a volume key to see the volume status bar at the top of the screen. Use the volume up and volume down keys to adjust the loudness of the ringer (scale 0 to 30). Tap on the text next to the ringer icon to change the profile (vibrate only, ring+vibrate).
  2. Check if the issue is with a specific ringtone: Go to Settings > ringtones+sounds > Ringtone, and tap on a playbutton to preview the ringtone.
  3. Switch off the ringer vibration (Settings > ringtones+sound > vibrate) temporary, to determine if your phone is affected by any motion settings i.e. Flip-to-Silence.
  4. Make sure that call forwarding is not switched on: Tap the phone icon > ... > Settings.
If the problem persists, restart your phone by pressing and holding the power and volume down keys simultaneously until the phone vibrates. Release and the phone will restart. After this operation, you may need to re-adjust the volume and set date+time on the phone. Note that this does not remove your personal content.
Mar 13, 2014 | Computers & Internet
When i recieve a text message there is no ring tone or vibrate
plz check your sound setting.for that
instructions are:
1. go to your phone's "setting".
2. enter into "sound".
3. "ok" or "click" on "vibrate".
4.and if you want ringtone at received time than go to "phone ringtone" below vibrate option.
Aug 17, 2012 | Samsung SGH Cell Phones
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Jan 25, 2011 | Samsung T239 Cell Phone
My Slice phone no longer rings out loud or vibrates when a call comes in. How do I restore those settings?
Check out this link for a PDF manual for your phone. Just copy and paste into your browser.
I got this info off of page 60 from your manual.
Control the volume for Ringtone, Speakerphone, Headset, and Advanced settings.
Set ringtone volume and incoming call alert options:
1. Press [Menu], then press "Settings".
Press "Sounds", then press "Volume".
2. Press "Ringtone".
3. Press / to adjust the volume level. Press to select Vibrate when High is the volume level.
The volume settings available are:
• Silence all: All sounds are off.
• Vibrate : Phone will vibrate to alert you of incoming call or message.
• Off: Only the ringtone is muted.
• Ringtone mode: Low, Medium, High.
Tip • You can adjust the ringtone volume with the side keys.
Hope this helps. Let me know if I can help you with anything else.
Oct 05, 2009 | UTStarcom PCS1400 Cellular Phone
Samsung i616, Ringtone file corrupted
Best way I have found is to use explorer and browse into your mobile device and search for a folder called "volatile". I copied every wierd looking folder that started with XME or such. There were like 999 of them on my phone. Once they were removed, everything went back to normal!
Mar 13, 2009 | Samsung BlackJack Smartphone
Ringtone volume problem
do you have it on vibrate along with the ringtone? sometimes they place the vibrate under the speaker so you can barely hear the ringtone if it's on vibrate..
Jun 28, 2008 | Samsung SGH-D600 Cellular Phone
All My Ringtones have disappered from my phone
Press the volume up button on your phone. It is set to vibrate. You must turn up the ringers.
Nov 19, 2007 | Motorola Mobility Boost i415 Cellular...
Samsung Blackjack SGH-I607 Smartphone Logo
398 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
