I just had the clutch replaced
You pulled the transaxle and replace the clutch disc, pressure plate and throwout bearing< really?
the first thing, for all hydr. clutch actuators is to test it with 2 persons.
you depress clutch
and person two ganders at the clutch lever into bell housing. of trans-axle. then sees if it moves 3/.4 to 1 inch. if not , the MC or slave
clutch actuator is bad. replace it.
is the clutch MC reseviour. low? or empty
SOURCE: Clutch problem
check the fluid level first, if its empty this will happen, if so full it and bleed the clutch, if not it could be the slave cylinder and failing both, it could be the clutch itself, easiest way to check is to see on the gearbox if the clutch is engaging when you press the pedal down.
just ask if you need more help
SOURCE: Rear speaker size in my 1993 Honda Accord
I HAVE A 93 ACCORD LX AND ACCORDING TO HONDA MINDS COME WITH 6.5" SPEAKERS FOR THE BACK AND TO GET 6X9 IN YOUR GOING TO EITHER GET THE SPACER THE COME WITH THE EX OR YOU OR GOING TO HAVE TO CUT AND THEY DONT RECOMMAND IT CAUSE YOUR TRUNK WONT STAY OPEN AND YOUR GOING TO HAVE TO BEND THE BAR UNDER THE TRUNK. HOPE YHIS WAS HELPFUL.
SOURCE: 1996 honda accord LX auto trans problem
yes..sir you must take your car to the nearst Honda Service Station and ask to the mechanic there to check the transmission and replace the clutch with new one. don't forget to check and maybe change all oil that have connected with your transmission. all work maybe take 1 or 2 days depend on the part that you need to change
SOURCE: 1993 honda accord wont start
yes hi. i had the same problem , it was fixed by replacing the fuel relay switch.
good luck.
SOURCE: how to replace clutch kit for a 1990 honda accord?
Go to your local library and check out one of their service manuals.They are free and you can check them out anytime.As long as you return them.Good luck.
