Question about Kenmore 46462 Front Load Washer
How do I Replace the bellow on a Kenmore 4646
The rubber gasket between the front of the washer and the basket (bellow) has a tear in it and water leaks out the front of the washer.  How do I replace it?
Sean
  • 2 more comments
  • Anonymous Dec 17, 2007
    I have the same problem and have ordered the bellow.
    I am also lookign for advice on how to replace it.
  • mimimc Jan 03, 2008
    Same problem. I orderd the part and now trying to get info on how to replace it.
  • Anonymous Jan 08, 2008
    Same problem. I have the part and I need help!
  • mrfixitone Jan 22, 2008
    same problem, can't get the old gasket off, need help!!!1
There is a spring that holds the gasket on .Pop that spring off and the gasket should come very easy.
Posted on Jan 26, 2008
Whirlpool duet washer is putting holes in clothes. The gap between the stainless drum and rubber bellows is about 1/2 inch. Do I need to replace the bellows or the drum?
Tearing or holes if tearing pull the bellow forward and inspect the lip of the front tub for rough spots place your hand in the basket and see if you can push upward looking for play should not have any if so tub bearing worn of holes take a flashlight and inspect the SS basket looking for raised dimples.
Sep 04, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Torn rubber gasket
The front door seal is referred to as the "bellow". They do wear out with age and can also become mishapened from repeated pressure from the door being closed. Over time the bellow can stretch or develop rips and tears and begin to leak. If the bellow is leaking, or no longer sealing correctly, the following link explains how to replace one:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need.
If you have any questions, please post back and let me know. I hope this helps you.
NOTE: If you leave the door OPEN between washes this will help prevent constant pressure on the door seal which can stretch it out of shape over time. It is also beneficial to allow the wash tub to air out to prevent mold and mildew from forming. Also DO NOT overload the washer. This can contribute to premature wear of the door bellow and cause rips and tears.
Apr 08, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My ht3 #4292 is leaking water from the door
If water is coming through the door bellow and into the tub and not the floor, this is commonly caused by a water inlet valve that is leaking by or a pressure switch malfunction. The following link explains how to diagnose the problem to determine which one is causing your problem:
http://www.fixya.com/support/r3753262-front_load_washer_fills_when_not_in_use
I included parts resources and instructions on how to replace each component as well.
If you have water leaking on the floor, you may also have a bellow with a rip or tear. If the bellow is leaking, it must be replaced. Pull back the rubber folds and inspect the entire perimeter around the door to be sure. If the bellow needs replaced, the following link explains how:
If you have any questions about any of these repairs, please post back and let me know. I hope this helps you.
Mar 11, 2010 | Kenmore Elite 45986 Front Load Washer
The rubber gasket that keeps the seal when the door is closed has a tear in it, is it easy to replace??
Replacing the rubber gasket (bellow) is not a difficult process. If you are attempting to replace the door bellow on a Whirlpool front loader, the following link explains step-by-step how to replace one:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Read through the link provided and let me know if you have any questions.
NOTE: There is another method you may try as well. Although I do not prefer this next method because these washing machines are heavy, an alternative way of replacing the door bellow is to remove the lower toe panel and tilt the washer back at a 45 degree angle instead of removing the washer front panel. If you use this method, make sure it rests against the wall and will not tip forward. This allows the wash tub to drop down and away from the front panel and gives you access to the the rear bellow clamp through the bottom. This can save you some time. Thanks to user DGBG for the helpful tip!
If you would like some helpful exploded view diagrams of your washer that you can reference, you can use any of these web sites:
Just use your model number to begin your search criteria.
If you have any questions, please let me know. I hope this helps you.
NOTE: These door seals do wear out and require replacement from time to time. However, overloading the washer to the point where items get caught in the door area can contribute to premature wear and tear.
Oct 20, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE 2t washer is leaking from the front
thats called a bellow. from a scale of 1-10 id say a 9. front assy of washer needs to come apart to be able to get to gasket rear. that is why it leaking just a small tear or bend on the gasket bye the door will cause it to leak. ive done about 50 of those and it takes me about 1 hr. good luck .if u need furthur assistance let us know. thank you.
Oct 07, 2009 | Kenmore Washing Machines
Kenmore HE 3t Front Loading washer, rubber seal torn
fix ya..do it your self and save big,,im going to talk you through..and give you the part number...what you need is the bellows part # 8182119...ok vack unplug unit..open the door,,now you see the front lip of the bellow theres a wire with a spring stick a srew driver and pull off,,wire off ..ok now look in the unit right behind the front panel and in front of the tub in the upper right hand corner of tub font or bellows backside there a nut take screwdiver and losen pull bellows off,,easy to put back just reverse but open clamp a bit on back...onthejob
Jan 27, 2009 | Kenmore Elite 45986 Front Load Washer
Chenging the rubber gasket attached to kenmore H2e front load washer
The following link provides you with step-by-step instructions on how to change the door bellow:
This is not a difficult repair. Just follow the steps provided. If you have any questions, please let me know. I hope you find this information helpful.
Sep 02, 2008 | Kenmore Elite 45986 Front Load Washer
Washer is leaking
Check the rubber bellow (gasket) around the door. This is the symptom of a door gasket that it starting to leak. Pull the rubber folds back and check the area where the gasket attaches to the wash tub. You may have a crack or tear. If the gasket is worn please replay back to this post and I can give you advice on how to replace it and where to get a replacement gasket.
May 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
KENMORE HE3T BASKET RUBBING ON THE PLASTIC FRONT TUB
if ripped obvioussly youl need to replace the front rubber bellow, i would remove the bottom panel and have a look inside sounds like you have a broken shock aborber or 2 not properly supporting tub assy
Feb 18, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washer tub slowly fills with water
Is your problem a SLOW FILL problem, or a problem with WATER DRIPPING FROM THE RUBBER DOOR SEAL - or BOTH? If you have a slow fill problem, this is generally caused by a bad fill valve, which can be attributed to hard water deposits or well water mineral deposits. Sometimes the fill valve can be removed, cleaned and reinstalled, but most of the time a new fill valve is required. If you are experiencing water leaking from the rubber door seal (bellow), it may be time to replace it. Sometimes the seal can develop a wrinkle or crease where it meets the glass, which can cause leaks. Water dripping from the door when you open after washing a load is normal. Water dripping during a load is NOT. The bellow may also have started to rip or tear inside the door which may not be noticeable until you pull the folds of the bellow back and look underneath it. I hope this helps.
Jan 17, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 46462 Front Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
