This problem should be removed because:
Problem with Kenwood KAC-719 Car Audio Amplifier
want to bridge my subs I have a kenwood kac-719
I want to bridge my two subs to my kenwood kac-719
Solutions (1)
Best Solution
from what i have read about your amp, it is already a mono amp, and rated for 2 ohm's, so all you have to do is wire the subs in parallel (both positives together to positive and both negatives together to negative) or series/parallel if you have dual voice coils (both positive and both negative paired on each sub, then positive from amp to positive on one sub; negative on that sub to positive on next sub; then negative on sub to negative on amp) Note though, with two dual voice coil subs, you can have a 1 ohm load with the first set up, which can damage your amp. Let me know if this helps :)
Kenwood KAC-6201 AMP
i have a kenwood kac 6201 amp it will run find for a while then it will just shut off and if i turn my deck off and back on the amp turns...
connecting subwoofer to kac-7201 kenwood amp
I want to connect my existing subwoofer to my kenwood kac-7201 car audio system. My subwoofer has two input wires each accepts one single...
just woundering if i could bridge one sub to front
just woundering if i could bridge one sub to front and one to rear the subs are kenwood w3514 dvc subs the amp is kenwood kac-x501f
The subs aren't pushing out bass.
Everything is brand new. I have a Kenwood 6202 amp and 2 12" kenwood subs. I hooked everything up amp works and everything, but the...
Add Your Solution
the fuse on the amp blows when i attatch the
the fuse on the amp blows when i attatch the remote wire. it has been fine for years now it keeps popping
My amp was turning off at first then just would...
My amp was turning off at first then just would not come on. I checked the wiring etc. Removed amp and opened it up. I...
red light blinks some sound but not enough power
the red triangular light on top blinks when i hook it up to the servo 2 channel the light blinks when it is on the...
Fix-O-Meter
362
362 people viewed this problem
- 2 people found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top Kenwood Car Amplifier Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
