Question about Compaq Presario Notebook
Vga to tv, to show presatations
I have a laptop acer aspire with only a vga, and i need to no how to hook it up to a tv with only video or s video hook up so i can show presatations on the tv. i ordered a convertion cable vga to s video, red, white, yellow, but it still don't work. i tried turning on the 2 monitur, but it says it can not find it to conect. i don't no why, can u help?
  • 1,006 Answers
Re: vga to tv, to show presatations - Compaq Presario Notebook PC Laptops
You need to have VGA WITH TV-OUT!!!
Posted on Oct 29, 2007
  • 4,889 Answers
You can buy an adaptor that takes vga as input..and has options for S-video,DVi outputs...It should cost you around 50$..Or if you have an svideo port on your vga card you can connect it directly..Most graphics cards will have it..Let me knw your graphics card model so that i can help you out..
Posted on Oct 30, 2007
0 characters
3 Points
Acer Aspire 5630 hook up to television
Your Acer laptop has a 15-pin VGA port on the rear. It may also have a S-Video and/or a DVI-D port. Any of these can be used to connect to a television monitor. None of these connections, however, supports the sound portion of the signal. You will therefore require two cables, one for the video, and one for the sound. The sound will be a regular 1/8" stereo jack on the PC side. You will need to look at the TV to see what types of connections it accepts. There may be HDMI, DVI-D, S-Video, or RCA connections. Select a cable which matches the connections for each end for both the audio and video.
Dec 11, 2013 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer support
Use the VGA and set the TV to VGA as well.
Oct 15, 2012 | Acer Aspire One D255E13438 Netbook
I wanted to know What do I need to play movies from my acer aspire 5315-2077 laptop right to my tv. what type of cords?
a vga cable- like you use for compute monitors. vga is your only video out on your laptop. most hdtvs have vga input.
Jun 27, 2011 | Acer Aspire 5315 15.4-inch Notebook PC
How do I connect the Acer netbook to the TV?
The only option is using the VGA port on the Aspire One to hook it up to the TV.
Your TV must have a VGA in port for your to be able to hook your computer to your TV. All you need is a regular VGA cord.
Mar 26, 2011 | Acer Aspire One Netbook 8.9" Notebook
How do I hook my tv up to my acer netbook? I dont have a tv port but do have a port for a second moniter and have the cord to hook it up but it will not work...
If the TV doesn't have a VGA input, you have two options. If the TV has component video inputs (3 RCA jacks color-coded red, green and blue, not just a single video jack coded yellow), you can use a simple adapter cable. Here is an example.
If your TV only has a single yellow video input jack (called composite video) you can't use the simple cable. But you can get a VGA to video converter. This device takes the VGA signals and converts them to the form the TV can use.
Hope this helps. Thanks for using Fixya!
Mar 30, 2010 | Acer Aspire One PC Notebook
I have an acer aspire 5535-6637 and I was wondering if it is compatible with an S-Cable.. If not how can I watch things on my laptop from my TV. Thanks!
You may or may not be able to, it depends in part on your TV. The earliest interface that was compatible would be VGA but it may not be very good on resolution.
The specs for your notebook show only:
DVI Port, VGA port
The DVI (Digital Video Interface) port is available on later sets so check your user guide for either of those two and if VGA is the necessary choice, check which resolution the computer and TV share. DVI will adhere to the same standard for both.
BTW, when asking for help when interfacing devices, include model numbers for both; it saves us time and will give you a more accurate answer with fewer generalities.
Mar 27, 2010 | Acer Aspire 5535-5050 Notebook
I have an acer aspire 5100 laptop i need to hook up to my tv for a presentation tomorrow. there is no s-video output on it,. how do I hook it up to my tv?
If your TV has RCA jacks on the back or front. Input type. Then you can go to radio shack and get a vga cable to RCA jack converter. That is all you can do. Is the TV a flat screen if yes then you can hook up you pc with a monitor cable like your usine now in your house. Find out the type of TV.. Ask someone to check the tv for a computer port on the back.
Oct 09, 2009 | Acer Aspire 5100 Notebook
Hooking up to the tv, aspire one acer notebook???
hi there, try a 15 pin male vga to vga cable vga mode on monitor
May 17, 2009 | Acer Aspire One PC Notebook
What type to cable should I buy to connect laptop to tv
Youre laptop would have to have a video card that has a TV-out port... And for that you would have to run a S-Video cable from the TV-out port of your laptop to the S-Video port on your TV... I assume your TV has a S-Video port?
Mar 31, 2009 | Acer Aspire 5500 5570-2609 Laptop
Compaq Presario Notebook Logo
177 people viewed this question
Top Compaq PC Laptops Experts
John mullen
 Mike M
Mike M
Are you a Compaq PC Laptop Expert? Answer questions, earn points and help others
