Coleman Campers Grill Logo
A
Anonymous Posted on Mar 02, 2014
Need replacement stickers for my camper
I need replacement stickers for my camper. the ones that are on it is starting to peel off. now it looks really bad.
1helpful
How to remove window stickers on car windows
The best method is to use a blow dryer at a slight angle and not too close. To assist in removing, once you peel back you can spray ammonia behind the sticker.
If you’ve found this helpful, please click the green “helpful” icon. If you have 20 seconds please leave a few words as a review or recommendation! Also, follow me for more answers to everyday issues, I’m all for saving you money and making the most of your time! Thanks and have a great day!
Where would I find the vin number on a travelage tow behind camper?
Hi Christine:
Try looking for a "sticker" on the inside of any cabinet doors, or a plate on the inside of any outside doors.
Also, look for a plate next to the outside of the entry door, or on the back outside of the camper.
The last possible would be the registraton papers which would tell you what the VIN is, but not where it is located on the unit.
Hope this helps.
1helpful
2answers
I have a Nordic track C2050 treadmill one day everything was working great the next day the only the #1 and #7 speed button worked decline up and down stopped working plus all program buttons not work
This is old I know, but it took me this long to figure this out. I did not find this answer anywhere else online. If you disassemble the console from the treadmill. Just a few screws in the back...then take off the magazine or tablet lip from the front of the console. Carefully peel back the button sticker and you’ll see the circuit grid for the buttons. One of them is stuck. So starting in the upper right of the clear sticker that holds the circuitry. Carefully peel the two layers apart. There is a top circuit and a bottom circuit sticker stuck together. i did this with the treadmill turned on but don’t stand on the belt while doing this. As you peel the top layer back you may hear some beeping as buttons come to life. For mine I peeled about halfway and then put the top layer back down. After a few peels and resticks all the buttons worked again! The only remaining issue is the 5 and 6 don’t work but up and down speed works so you can adjust that way. I would call this a last ditch idea but this is the issue that people are having. Your mileage may vary on what starts to work after trying. Maybe there are a few of these treadmills sitting out there collecting dust like mine was for 10 years. Mine has new life back in it!
2answers
Which holes do i use to refill the different colours in the inkjet colour cartridge
Hi
All printer are the same ways to refill the inks up go to this website it will show you how it done there is a few Videos there for you to see how it done
http://www.youtube.com/watch?v=pnCPB9Clk5c
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Card fan makes noise
Turn off your computer, if your familiar on how to open-up you CPU do so, then,
Try cleaning the fan.
What you can do is clean it with a bush (ex. paint brush-a clean one) or a clean cloth.
you can also try to remove the fan then at the center of the fan there's a sticker, you can safely peel it off then you will see the center of the fan, you can apply machine oil on it, then put the sticker back. Then turn on your computer, let's see if you still has the problem :)
I have a Pulsar PQ2001 LED wrist watch requiring battery replacement. The battery is covered by a sticker and seems to be ''clipped in.'' I afraid to try to force the 2025 battery out of its position. I...
You need to CAREFULLY peel back that sticker and on either side of that metal clip is a way to unclip it. I really would not recommend someone changing any of their batteries unless its a "cheapo" watch! If you touch the wrong area with the tweezers you could end up having to send it in for repair! Best bet here is to take it to a reputable watch repair shop and let them do it!
Jan 13, 2010 • Watches
Start Button
youll need to replace the entire console, the "sticker" is not sold seperatly
10helpful
2answers
Hp f4288 all in one black cartridge( N0.818) refilling method
when i fill this cartidge after finishing the cartidge is not printing why?
Top Coleman Sport & Outdoor - Others Experts
Kardoc
vince
john h
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
