Question about Kenwood KDC-217 CD Player
No sound I installed my stereo but there is no sound. All wires appear to be connected correctly. The wiring harness being used was working fine with my other Kenwood.
  • 20 Answers
It sounds like you have a short on two of your speaker wires just connecy front speakers and try then rear then left then right to prove which one or ones
chris
Posted on Oct 29, 2007
I have bought a 16 pin iso lead power wiring harness adapter to enable me to fit a panasonic stereo in my old BMW. Please could you tell me why the adapter has a brown wire which is not connected at one...
Harnesses are made for many vehicles. The harness you bought may fit another year model where the brown wire might be used. If you are not using this wire, just tape it up and secure it. It will be fine as long as everything is working on the stereo you have installed. good Luck.
Sep 08, 2011 | Panasonic 16 Pin Car Cd Wire Harness
Im trying to install a new radio into 1997 Ford Expedition w/premium sound. However I cannot get any sound. I have the wriring harness.
Hello... I am sorry to hear you are having a problem I am assuming that you are using a wire harness adapter to interface between your factory harness and the aftermarket radios harness. If the aftermarket stereo has a blue/white wire, you need to connect it to the blue and the blue/white wires in the adapter harness. This will turn on the amplifiers. If your aftermarket stereo only has a blue wire, then use it as the connection with the blue and blue/white on your aftermarket harness adapter. Hope this helps. If you need any further assistance, let me know!
20 year car audio/video installer
Bay manager
Mar 19, 2011 | Car Audio & Video
I had bought a dual xd1222 aftermarket stereo. i bought a gm2000 harness for it to hook up in my 2002 chevy cavalier. i have all the wires connected but when i hook it up in the carit will not work. what...
check the fuse behind the stereo and in your fuse box first off and make sure the power wire/ignition wires are on the correct pin. do this with a test light for verification. also check the ground wire. after you test and connect these 3 wires, the stereo should turn on. Your wiring harness may not be done correctly so visual verification with a test light would be the best thing before starting a car install. If this still does not work and the stereo you took out did, it is a malfunctioning unit.
Sep 11, 2010 | Dual Car Audio & Video
Installing an aftermarket stereo in 1996 explorer...sound issues.
You may have a factory amplifier in the rear of the explorer in the right cargo panel. You need to supply power to it by connecting the amp power on (Blue/White I think) in the dash to a power source (such as red on your stereo harness) so it comes on with the key. If you do have the amplifier, that's why you have no sound.
Oct 02, 2009 | 1996 Ford Explorer
AC display won't dim after stereo installation
If you disconnect the stereo, does the temp. display go back to working properly? Did you connect the stereo Illumination wire correctly? Are all the other stereo wires connected correctly? Double check what the wires in the aftermarket harness are supposed to be and don't just go by color.
Jun 17, 2009 | 1996 Oldsmobile Cutlass Supreme Coupe
Installing an aftermarket stereo, spliced the wires and have everything connected including the remote wire to the factory amp wire but still no sound.
There is no remote wire on these newer trucks....03 and up....u have to buy the harness....although i didnt....i have an 03 gmc sierra and just pulled the schematic and matched the wires. And there is no programming to do on an aftermarket stereo.....I work for GMC and we cant program aftermarket stereos......if u buy the right harness ...and its over $100 then everything should work just fine.....and this does not disarm ur alarm system either....mine still works fine....hope this helps
May 08, 2009 | 2003 GMC Sierra
Rear door speakers don't work w/ aftermarket radio in 94 suburban
You need to attach the blue wire on the stereo harness to the blue and white wire on the car adapter harness. they installed a small amplifier to power the rear door speakers and unless you connect those two wires then the speakers will not work.
Jan 05, 2009 | 1994 Chevrolet Suburban
Stereo display works fine, but no sound to speakers.
The wires may have gotten wet and fried something in the sound output in the stereo.
Jun 16, 2008 | Pioneer DEH-1900MP CD Player
Problem no sound
If your KENWOOD unit is experiencing audio problems (NO Audio), but do have audio when TUNER is selected as the source, you may have problems with your installation.
NOTE: If using an external amplifier or the unit was installed using a separately purchased wiring harness for your specific vehicle, please check the following
If Using an External Amplifier
The P.CONT or REMOTE terminal on the external amplifier requires a “turn on” signal from the stereo. This terminal should be connected to the BLUE/WHITE P.CONT wire on the Kenwood harness and not the solid BLUE ANT.CONT wire.
If Using a Vehicle Specific Harness
The vehicle has a factory installed amplifier and requires a “turn on” signal from the stereo. Make sure that the BLUE/WHITE P.CONT wire is connected to the vehicle specific harness and NOT the sold BLUE ANT.CONT wire.
The solid BLUE ANT. CONT wire is used to trigger a power antenna ONLY when the tuner is selected as the source. Using this wire to “turn on” an external amplifier or factory installed amplifier will only allow it to work when TUNER is selected. Please refer to your instruction manual for proper installation. If you are not completely comfortable with installing the unit yourself, we recommend that you seek assistance from a professional installer.
Apr 10, 2008 | Kenwood KDC-MP438U Car CD/ MP3 Player
Kenwood KDC-217 CD Player Logo
111 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
