Computers & Internet Logo
A
Anonymous Posted on Mar 01, 2014
Can get configuration addess to work
Cant get 192.168.0.50 to connect
Anonymous232
Level 3:
Genius:
  • D-Link Master 1,552 Answers
  • Posted on May 07, 2015
Anonymous232
D-Link Master
Level 3:
Genius:
Answers
1552
Questions
Helped
270278
Points
2945
Connect your computer to your router.
It should automatically get an IP-address.
Click the Windows "Start" button (Windows 7).
Type 'cmd' into the search-box.
Press ENTER.
Type 'IPCONFIG /ALL'.
Look for the IP-address of the "gateway", or the IP-address of the "DHCP-server".
That is the IP-address that you want to type into your web-browser.
Cant get it to take my email addess
Computer user. Can't get to take your emails address is not a question and thus unless you can rephrase your question, there is no probable answer.
D link des 800d switch configure ip addess for 2 computers on a network
D-Link DES-1008D 8-Port Ethernet switch is unmanaged switch which can only support 10/100 MBPS.The DES-1008D is a passive switch which means there is no way to configure the ip address and no need to.
No Internet access
make sure you can access the router configuration page
change you computer ip addess to match the ip address range of the router
ex if router is 192.168.1.1
set computer ip to 192.168.1.2
subnetmask 255.255.255.0
and set default gateway and dns server address to gataway address
geateway 192.168.1.1
dns server 192.168.1.1
try it most probably you need to make sure you have configured your adsl user name and password and other settings in you router since you have rested it
4answers
How do I change my I.P. addess...I'm having compatibility problems with my wireless router and cant get on line
1.
Control Panel
Network Connections
Wireless Connection
Properties
Make sure Internet Protocol TCP/IP is set to "Obtain an IP address automatically"
2.
Start/Run
CMD<enter>
ipconfig /release<enter>
ipconfig /renew<enter>
Cant find my ip addess
Try: Network Settings --> Settings and Connection Status List
Cant get my router to work
Connect the computer to LAN port one of the router using an Ethernet cable, access the configuration page (ie 192.168.1.254), configure the router as Dynamic IP, Configure the wireless network as (WEP or WPA), Check the IP address of the WAN section.
Note: If you have an IP address to the WAN section the Internet connection is working, Connect through the wireless network by finding the wireless network name was been created to the router.
1helpful
How to configure AX 150
EMC offers a great documentation site.
Here is it:
http://www.emc.com/microsites/clariion-support/ax150/install.esp?redirect=true
You can select Install and you can create a great customizes doc for installation steps.
Generally you can configure AX150 from a web based interface.
Enter the ip addess of the storage processor and a java application will appears.
You should do the following:
1. Create raid groups
2. Create LUNs on raid group
3. Register the hosts
4. Add hosts and LUNs to a storage groups
2answers
Ip addess
if you are using an ethernet cable make sure its connected directly into your Modem and not a port in your PC
Wireless card not connecting ti internet
Check if your wireless router is configured properly. try to reset the router to the default sitting
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
