Question about Samsung WF337AAL Front Load Washer
2e error on samsung dryer - Samsung WF337AAL Front Load Washer
Error Codes on our Samsung RF4289HARS refrigerator: Error Code: 6E, 2E, 25E, 73, 40E
https://removeandreplace.com/2015/08/10/samsung-refrigerator-error-codes/
Oct 28, 2017 | Samsung Computers & Internet
What does 2e mean on my Frigidaire dishwaher
Hello friend, thank you for your post!
I see you are having trouble with your Frigidaire dishwasher and you are receiving error code "2E". However, it appears "2E" is an invalid error code. May I have you model number please? Typically you can locate your serial tag on the inside wall on the left hand side. With this information I can better assist you with pinpointing the issue.
In the meantime, let's attempt resetting your range. You can do this by unplugging it or flipping the household circuit breaker to the off position for roughly ten minutes. This usually clears false error codes. -Matt
Sep 21, 2014 | Frigidaire Dishwashers
Have a code 2E
Hi there:
One 2E error occurs when washer detects a high or low voltage issue. In many cases, restarting the cycle clears the error.
Other posibilitie, could be the main control board is defective and needs to be replaced.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 17, 2011 | Samsung WF218AN Front Load Washer
MAH8700A Error code 2E What does this mean?
According to the trouble shooting manual that came with my Maytag MAH8700A, code 2E refers to "Voltage for motor control bus is under specified limit." It states that the action to be taken is to "replace motor control board."
Nov 04, 2008 | Maytag MAH8700A Front Load Washer
Samsung WF337AAL Front Load Washer Logo
355 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
