Question about HP DeskJet F380 All-In-One Printer
Printer how do you remove ink cartiages
  • Anonymous Dec 03, 2007
    two parts of printer open. i can see the cartridge under bottom one to the cartridgeon the rright. how do i remove it to replace?
    Scholar:
  • 121 Answers
Follow these instructions when the ink level is low.
Note When the ink level for the print cartridge is low, a message appears on
your computer screen. You can also check the ink levels by using the software
installed with the HP All-in-One.
When you receive a low-ink warning message, make sure you have a replacement
print cartridge available. You should also replace the print cartridges when you see
faded text or if you experience print quality issues related to the print cartridges.
To order print cartridges for the HP All-in-One, go to www.hp.com/learn/suresupply. If
prompted, choose your country/region, follow the prompts to select your product, and
then click one of the shopping links on the page.
For a list of print cartridge numbers, see the back cover of this guide.
To replace the print cartridges
1. Make sure the HP All-in-One is on.
Caution If the HP All-in-One is off when you open the print cartridge door
to access the print cartridges, the HP All-in-One will not release the
cartridges for changing. You might damage the HP All-in-One if the print
cartridges are not docked safely on the right side when you try to remove
them.
2. Open the print cartridge door.
The print carriage moves to the center of the HP All-in-One.
3. Wait until the print carriage is idle and silent, and then lightly press down on a
print cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge
from the slot on the right.
Chapter 8
28 HP Deskjet F300 All-in-One series
Maintain the HP All-in-One
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
4. Pull the print cartridge toward you out of its slot.
5. If you are removing the black print cartridge in order to install the photo print
cartridge, store the black print cartridge in the print cartridge protector or an
airtight plastic container.
If you are removing the print cartridge because it is low or out of ink, recycle the
print cartridge. The HP Inkjet Supplies Recycling Program is available in many
countries/regions, and lets you recycle used print cartridges free of charge. For
more information, go to the following website:
www.hp.com/hpinfo/globalcitizenship/environment/recycle/inkjet.html
6. Remove the new print cartridge from its packaging and, being careful to touch
only the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
Caution Do not touch the copper-colored contacts or ink nozzles.
Touching these parts can result in clogs, ink failure, and bad electrical
connections.
User Guide 29
7. Slide the new print cartridge forward into the empty slot. Then gently push on the
upper part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
8. Close the print cartridge door.
9. If the print cartridge alignment sheet prints, load it on the left front corner of the
glass with the top of the page to the left.
10. Press the Scan button.
The HP All-in-One aligns the print cartridges. Recycle or discard the print
cartridge alignment sheet.
Posted on Oct 29, 2007
How to fix Artisan 1430 printer the Ink are not responding and the Ink cartridge
ink cartiage not moving or not spaying ink? If not spaying ink, remove ink carts and use a needel with 1/8 in tube to blow air down ******* that are found under carts. the blocked ones will have resisants and can be unblocked by pressing the air throught the plunger
May 15, 2016 | Epson Artisan 1430 Printer
My printer keeps saying to install a ink cartiage but there is one already in there.
Solution 1. you need to remove and return tightly the ink cartridge.
Solution 2. maybe you purchase ink cartridge that are not compatible with the printer.
Solution 3. if you are only refilling the ink cartridge, maybe it is worn out and the printer is no longer detecting the cartridge due to wear and tear.
Nov 26, 2010 | Dell Office Equipment & Supplies
Printer works however NO INK on page all new cartiages
The new cartridges comes with seal wrapper on nozzle, have you remove it or not, if you have already remove it the reinstall the ink cartridges and try to print.
Regards
Ashly82
Feb 01, 2010 | HP Business Inkjet 1000 - Printer - colour...
Printing is blank...no ink coming out on to paper
Your printer cartiage will be out of ink.
Or it will be dry cause of not used from long time.
Change the printer cartiage may fix this problem.
Thanks.
Oct 09, 2009 | Office Equipment & Supplies
How to remove the ink catridge of hp deskjet F4288
Power on the printer ,
Open the right most corner cover when facing to printer ,Cartiage container will rest to stable position ,hold cartiage from top and twist it towards your direction ,it ill come out
Mar 14, 2009 | HP xw6600 Workstation with 650W 80 PLUS...
Ink cartiage not proparly install but my ink cartiage refil
ink cartiage not properly installed ae shown but my cartiage are riffil
Jan 28, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Conon ip1800 series
Because in refill catridges some connecting link is problem, remove the refill catridge and install the new catridge
Jan 16, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
The ink cartiage cannot be inserted
do you have a digital camera? if you do can you please take a few photos of the ink and of there it goes in the printer and post them back on here?
Nov 15, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Command do not delete
compltely switch off the computer and start again the command will then be delete. your suggestion is too costly to pay.
Aug 05, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP DeskJet F380 All-In-One Printer Logo
348 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
