Question about HP PSC 2210 All-In-One InkJet Printer
Receiving fax Sending fax no problem, receiving fax does not work. Help!
  • 3 more comments
  • FORREAL Nov 09, 2007
  • carim Nov 13, 2007
    No problem sending but cannot receive. Can someone walk me through the steps please? Sometime someone will send a fax but it comes through as a blank page. I do not have a dedicated fax phone line.
    Thank you, Cjm
  • kwasnicki Nov 18, 2007
    A communication error occurred during the fax transmission.
    Message states that Error 283* is the result.
  • Jake1142 Dec 20, 2007
    can't receive faxes. I can send faxes.
  • Anonymous Aug 25, 2008
    My RICOH fax machine has stopped receiving incoming faxes. Can you help?
  • 234 Answers
First step to check is if the auto answer is on in the fax machine.
And as there are multiple users with same issue but different model units,please be specific of the model number of the All-In-One you have.
For PSC2210 try the steps mentioned bellow:
Good Luck
For Communication Error 283
Check the resloution in the link bellow:
Good Luck
Posted on Sep 12, 2008
Help with Sharp Fax UXP100 . When sending a fax they are going very, very slow. What should I troubleshoot? Thx
Check your phone line by removing fax and plugging a normal handset into the line socket and then listen to line. If a line has noise on it, it will slow transmission down, it can also cause wiggly lines on transmitt and receive, if this is the case, it needs to be dealt with by your phone line provider, just report a noisy line
Having the machine set to fine in transmission settings can also cause slow faxs, and a dirty scanner glass can also cause receiver image to have marks on received image but it is normally marks down the page
hope my good deed free for the day helps.
Nov 22, 2011 | Sharp Office Equipment & Supplies
3055 fax not working, sendng or receiving directly
Below is a link to an HP tech site. They helped me with MY hp all-in-one. It turned out I needed to download a different driver from HP's tech website (the download is free) and that is probably what you will be doing, also. God luck.
Jul 08, 2009 | HP LaserJet 3055 All-In-One Printer
Setting up fax machine to receive
Receive Mode Setting
On the operation panel, press the following buttons to select the appropriate receive mode.
  1. Press <Fax>.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode set], then press <OK>.
  4. Press the right or left arrow button to select the receive mode that best suits your needs, then press <OK>.
    FAX ONLY MODE: When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only.
    MANUAL MODE: When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually.
    ANS MACHINE MODE: When you want to receive voice messages on your answering machine and receive faxes automatically.
    FAX/TEL AUTO SW: When you want to receive faxes automatically as well as voice calls.
    DRPD: When you have subscribed to a DRPD service with your telephone company.
  5. Press <Stop/Reset> repeatedly to return to fax standby mode.
Sending Methods Sending From Your Machine (Memory Sending)
  1. Load the document on the Platen Glass or the ADF.
    Sending from the platen
    Important: When sending a double-sided document, set the document on the Platen Glass. You cannot scan double-sided documents from the ADF.
    Sending from the ADF
    *MP830 shown
  2. Press <FAX>.
  3. Adjust the settings for your document as necessary.
  4. Dial the recipient's number using the numeric keys or speed dialing.
  5. Press <Color> for color sending, or <Black> for black & white sending.
    • When the document was loaded on the Platen Glass:
      1. When the following message is displayed, load the next page on the Platen Glass.
        If you have only one sheet to scan, press <OK>..
      2. Press <Color> to send in color, or <Black> to send in black and white.
        IMPORTANT: If you do not press the same button you pressed in step 5, the machine does not start scanning.
      3. Repeat steps 5a and 5b to scan in all pages of the document.
      4. Press <OK>.
    • When the document was loaded in the ADF:
      The machine starts sending automatically after the document is scanned in.
      Note: Color sending is available only when the recipient's fax machine supports color faxing.
  • To cancel sending before sending a fax, press <Stop/Reset>.
  • To cancel memory sending while sending a fax, follow any instructions on the LCD after pressing <Stop/Reset>.
  • If the document remains in the ADF after pressing <Stop/Reset> during sending a fax, press <OK>. The remaining document is automatically fed out.
Sending From Your Machine (Manual Sending)
Use manual sending when you want to talk to the recipient before sending a document, or if the recipient does not have a fax machine that can receive automatically.
  • With manual sending, you cannot use the Platen Glass to send documents.
  • You will need to connect a telephone to your machine if you want to talk to the recipient before sending a document.
Follow this procedure:
  1. Connect a telephone to your machine if you want to talk to the recipient before sending a document
  2. Load the document in the ADF.
  3. Press <FAX>.
  4. Adjust the settings for your document as necessary.
  5. You can lift the handset if one is connected to the machine.
  6. Dial the recipient's number using the numeric keys or coded speed dialing.
  7. Talk through the handset to the recipient. (If you hear a high-pitched signal instead of the
    recipient's voice, go to step 9.)
  8. Ask the recipient to set recipient's fax machine to receive faxes.
  9. When you hear a high-pitched signal, press <Color> for color sending, or <Black> for black & white sending. Then hang up the handset.
Jan 07, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Doesn't receive from two fax numbers outside the UK
I would suggest there is nothing actually wrong with your machine, as you can indeed receive faxes from other parties. The problem mostly likely lies with the equipment and/or lines of the sending party. One thing you might suggest to them is to turn off ECM (Error Correction Mode) and/or lowering the sending/receiving speed of the machine - preferably the sending speed of the sending party.
Nov 09, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Internal Error 923 with Sending or Receiving Fax
I've just got my CLX-3160FN and found the same problems. Could go around the sending error, but can't receive faxes yet, always error 923.
Sending: make sure you press the "On Hook Dial" button before entering the recipient's number. Stupid, very stupid, but it's how it works.
Oct 12, 2007 | Samsung CLX 3160fn All-In-One Printer
Sending Faxes
When the last page of your document has been sent successfully, the machine beeps and returns to Standby mode. When something goes wrong while sending your fax, an error message appears on the display. If you receive an error message, press Stop/Clear to clear the message and try to send the document again. You can set your machine to print a confirmation report automatically each time sending a fax is completed. If you get the error message write it down it should always supply an error message if the fax did not go through.
Jul 25, 2007 | Samsung SCX 4521F All-In-One Laser Printer
My hp 3055 has not been receiving any faxes
The only thing that I can think of for you to do is to completly delete it from your computer & then re-download it. Only do this if you get no other resolution. Or you can call 1-800-474-7739 for hp technical support. I just did & they were a great help to me!
Jun 05, 2007 | HP LaserJet 3055 All-In-One Printer
HP PSC 2210 All-In-One InkJet Printer Logo
88 people viewed this question
Ben Johnson
