Question about Lexmark E240n Laser Printer
Paper emerge with bent corner
Recently, the Lexmark has been printing pages from the main tray with a small bent corner on the upper left side. I checked and double-checked the inside to see if there was an obstruction of some kind, but no luck. If I print to a thicker stock the corner does not get folded over. I'm willing to break the whole thing down, but would like to get ahold of a document that tells me how to do so I don't screw up this otherwise very good printer.
HandsofTime
  • 137 Answers
SOURCE: Setting for thicker card stock
Hi you can download it here it is part of the X1100 series.
http://www.lexmark.com/publications/pdfs/x1100/eng/ug.pdf
Regards
Hands of Time
Posted on Apr 21, 2008
SOURCE: Somebody has messed with the settings and now whenever we print we have to press "Select" for each page
The tray 1 is same as manual tray, it opens in front of you.
normally (in windows) you need to configure printer driver from printers => properties => printing preferences.
Posted on Oct 14, 2008
  • 141 Answers
SOURCE: when printing duplex document 1st page is upside down
make sure the driver is set to book bind duplex, rather than tablet style which is what it is doing now. Good Luck!
Posted on Dec 29, 2008
yooperbud
  • 8637 Answers
SOURCE: Lexmark E238 paper jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 22, 2009
  • 13 Answers
SOURCE: Printer problem
Check your paper configuration. Make sure Tray 1 is configured for Plain paper and is showing the right paper size. If it is configured for anything other than Plain Paper, most of your jobs will not print. Also, if the size says something like Univseral, then the printer is not touch that tray unless your print job also specifies Univeral as the size. If is does say Universal, check the paper guide in the tray and make sure it is pointing exactly at the paper size you are using
Posted on Feb 06, 2009
Tip
On the older Canon 6085 copier
From my understanding there are two types of NP 6085 copiers. To get into the service menu on the older type you will need to open the doors above the 2 paper trays and look on the right hand side for a small hole. Once you find the hole insert a bent paper clip into the hole to depress a switch. If done correctly you will see an S in the upper left corner of the display. Then hit the following *4*. that will put you into service menu.
on Jan 13, 2009 | Canon NP 6085 Copier
T652n 202.03 paperjam
1Open the upper-front cover and remove the toner cartridge.2
Look into the printer. Remove any jammed sheets of paper that you find there.
  • If the print job only consisted of this one page, reinstall the toner cartridge and close the front cover. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If the print job consisted of more than one page, confirm the entire paper path is clear before printing again. Do the following:
    1. Remove the top paper tray ('Tray 1').
    2. Remove any jammed or partially-fed sheets of paper you find here, then reinstall the tray.
    3. Go around to the back of the machine and open the upper-rear cover. Remove any jammed sheets of paper you find, then close the cover.
    4. Once you have confirmed that the entire paper path is clear, reinstall the toner cartridge and close the front cover.
    5. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If you cannot locate any jammed paper under the toner cartridge, then check the rest of the printer for any jammed paper. Do the following:
    • Remove the top paper tray ('Tray 1') and look for any jammed or partially-fed sheets of paper.
    • If you do not find any jammed pages there, reinstall the tray and go around to the back of the machine. Open the upper-rear cover and look there.
    • If the entire paper path appears to be clear, close the rear cover and power off the printer. Reinstall the toner cartridge and close the front cover. Power the printer back on. If a 200 error continues on power up, a sensor in the printer may be malfunctioning. This will require a service call to correct the issue. Please contact Lexmark Technical Support for additional information (see Contacting Lexmark Technical Supportbelow for details).
Aug 28, 2012 | Lexmark T652N PRINTER OPPENHEIMER SPECIAL...
HOW TO TAKE BROTHER PRINTER OFF OF MANUAL FEED OPTION
Hi there!
The message that ask you to manually feed the paper will appear if you have recently printed on a different type of media.
Does this happen from only one application like Microsoft Word? If it does try printing a test page or a document from other application like Notepad or Wordpad.
If the same issue occurs go to the Printers folder (under control panel) then right click on your Brother printer icon, left click on Properties, click on Printing Preferences and make sure that Tray 1 is selected for the tray, Plain paper for paper type. If changes have been made make sure to click on the apply button to apply the changes.
If it only happens to one application like Microsoft Word. Click on File ( or the orb icon on the upper left hand corner) then Print, then Print again click on Printing Preferences and make sure Tray 1 is selected and Plain Paper.
Hope this helps! Thanks
Jun 09, 2011 | Brother MFC-7820N Laser Printer
Only prints from the MP feeder and not through tray 1 anymore
if your printer only prints from the mp tray this is saying that it no longer recognizes tray one.
the first thing to check is the paper size fingers on the side of the tray. pull the paper tray all of the way out of the printer. there is a snap in plate on the left side of the tray. for letter size paper 2 fingers should be sticking out. if the fingers are present and not broken off. look into the opening that the tray was removed c
from on the left side half way back there will be 4 metal tabs make sure these are even and straight. if both of these are not damaged.remove the logic pack (metal cage behind the left side cover. loosen the 6 screws and remove the out cover. on the inside of this box remove the screw located upper right hand corner, remove the screw in the lower right corner, and the screw from the upper left corner. now one more screw on the back of this box lower left corner remove this screww then pull up on the box and set it aside. at this point you will see the main motor drive in the middle of this side dierictly under the motor you will see a small pcb that is attached with 2 screws ramove these and rfeplace this board it is the paper size select pcb and it needs replaced
Jan 06, 2011 | Lexmark Optra T610 Laser Printer
Hello i have a lexmark t630 and when it prints out of tray 2 it says change tray two and beeps. It will work normal if you hit the select button. What could it be?
the printer is telling you that the tray is reporting the wrong size paper. print the network menu from tray 2 if it prints out smaller than the page it will be reporting smaller than letter. if the bottom line of the outline is missing its reporting legal size paper. if you are running lettersize paper in the tray check on the left side of the tray half way down the drawer you will see a plastic snap in plate with 3 fingers the bottom 2 should be sticking out for letter size paper. you only have to be one of the small adjust teeth off to make the third finger stick out and report the wrong size paper this is a very common issue. look at the metal fingers that stick out of the frame of the options tray to make sure they are uniform and straight. if the fingers are set right and not damaged then the logic board in the tray assembly will have to be replaced
May 14, 2010 | Lexmark T630 Laser Printer
Lexmark E 342 n paper jam with error code 201
According to the LexMark support page, this is most often related to not getting the print cartridge assembly properly positioned. (Left and right sides not fully in place). Another possible source is paper in the output tray when using the double sided printing feature. (This leads to grabbing an extra sheet when it tries to retrieve the paper to print the second side. Paper stock thickness will change the number of pages printed before this happens.).
I hope this helps.
Sep 03, 2009 | Lexmark E342n Laser Printer
How do I copy a document on a lexmark x 1185 printer scanner copier
Turn the documents printed page away from you. (Document facing you, turn it around so that the print is on the backside)
Insert it in the top paper feed tray. Align the left side of the document page, with the alignment bar on the left side of the top paper feed tray. (Put the left side of the paper against the plastic bar on the left side of the paper tray)
Computer running, Windows loaded. Go to Start>Hover your mouse cursor on All Programs>Lexmark>Lexmark Printer
Click on the Copy function, and go to the Properties window to set how many copies you want, (Default setting is 1), what size paper you're using, and so on.
Jul 13, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
Paper Jam
It sounds like during one of these jams, a piece of paper was probably left over in there and maybe stuck "out of sight" in the paper path causing the paper to pulled to one side.  Look closely, my guess is that it is only a small corner of a page that is stuck in the path.
Mar 29, 2009 | Lexmark X1270 All-In-One InkJet Printer
Canon MP600 not printing on full page - in upper left corner
I went to the Canon website and downloaded the drivers for the printer and it printed out right--on a full page.
Feb 14, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Lexmark E240n Laser Printer Logo
83 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
