Home | Maytag | M3DH30B2A Dehumidifier | Water goes in res...
Maytag M3DH30B2A Dehumidifier
Problem for Maytag M3DH30B2A Dehumidifier
Water goes in reservoir, not thru hose to sump pump, leaking
By marksue8 on Jun 11, 2009
Our dehumidifier fills up with water in the reservoir, even though a hose is hooked up for it to drain to our sump pump, so we have to empty it manually, constantly; also, now it is leaking from the bottom of the unit, and after I took out and emptied the reservoir, there is water somewhere else in the unit, and this is where the water is leaking out. Our unit is about 3-4 year old.
Solution #1
posted on Jun 23, 2009
Somewhat Helpful)
gary1121
Rank: Wiz
Rating: 85%, 110 votes
blow some air thru the discharge line,, thats all it is the line is clogged, if the pan is filling with water, it is working but they do get clogged with dust and lint in the air,,
Comments:
Jun 29, 2009
- you need to take some vinagar and run it thru there are scales built up on the filter and you will have to take it apart to clean it, after cleaning it and putting it back together it will work, it is clogged where the drain line is
Was this helpful?
Yes
No
Popular Solutions for Maytag M3DH30B2A Dehumidifier
Questions and Unsolved Problems for Maytag M3DH30B2A Dehumidifier
Do you recommend Maytag M3DH30B2A Dehumidifier?
Answer
Answer
Runs for awhile then it actually gets ice on the inside where the water falls into the container.... (More)
Answer
My Maytag M3SH30B2A dehumidifier runs but wont't collect water. I just got done cleaning the filter... (More)
Answer
My Maytag Dehumidifier has been constantly running. But, it now seems it is only the fan we hear and... (More)
Answer
My M3DH30B2A (30 pint) dehumidifier smells somewhat rotten. Still completely functional. Help?
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Maytag M3DH30B2A Dehumidifier:
Top Dehumidifier Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dehumidifier Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
