Drained old gas out,cleaned carb and bowl with carb cleaner,replaced new plug gapped at .70 now what?
That's refreshing! You've already done a lot of the work!
First, try regapping it at about .040, see if it starts there. If not, check compression.
Does it generate any spark at all? Try it with a screwdriver instead of the spark plug. If none, track back to the magneto - also check any shutoff wiring at the magneto.
Um... you DID put fresh gas INTO it, right? 8) If you take the bowl off temporarily, does gasoline drain freely from the bottom of the carburetor?
SOURCE: craftsman snowblower will not kick over
Old gas? Did you pull out the spark plug and see if you have a spark? If the gas is old, drain the tank and line to the carburator, then put in fresh gas. Never put it up for the summer with gas in it. Run it until the engines runs out of fuel, then put it away.
If there's no spark, then you have a coil issue.
