Question about Sony VAIO PCV-RS530G PC Desktop
A Open Computer running Windows XP is
The PC is coming on like it normally boots up, then I get the "Windows" screen, then just a blue screen with "Windows XP" showing in a small icon, but I never get my Start up menu or program icons showing (it just stops there). After about 20 minutes, I get a "run time" error.
How to open sony vaio pcv-rs 530 g,because i would like instal a memory stick...........
Thanks
azhar
Posted on May 25, 2008
Thanks
azhar
    Scholar:
  • 160 Answers
It may be due to the missing of DLL files. for solving this my suggestion is to re-install the OS and drivers.
Let me know if your problem is solved and rate me as FIXYA!
Posted on Apr 29, 2008
  • 1,006 Answers
Run with safe mode and go with admin privileges then when u are in go START -RUN - TYPE THERE ( MSCONFIG ) -startup and desable all startup items and restart the pc!!!
Let me know if u get help OK?
Posted on Oct 29, 2007
Windows will not boot past the blue windows xp screen
You could try to restore to an earlier version of your system. This link will explain how to do that.
Mar 01, 2012 | Dell Dimension 2400 PC Desktop
I turned on my modem, an all that is displayed on my monitor is the blue hp screen. In the botton left hand corner it says <F10=Setup> and <Esc = Boot Menu> and in the right bottom corner, it...
what modem, who's and where, ?
or is modem , monitor?
which blue HP screen there are many,
you left out what it says...
i can not watch you boot, and what is displayed, is key to the cause.
NO OS stated, is this XP?
when you boot, it always prompts in text ,hit ESC key to enter setup"
this is the BIOS hot key prompt that some times shows
a cute small HP icon this too is BIOS created.
then the PC boots and goes to OS, there many OS offered
Windows is XP is one? is it?
or Vista.,w7,/8/10 or PS/2 or linux. HP has many offered OS.
as do Refurb companies endless.
if windows?, the windows log in screen is next.
so my guess is the PC goes to BLUE screen that, before that.
stating (presenting)
startup file failed?
or , HP recover failed.?
or any of 50 other windows blue screens of *****.?
why not post a photo of the screen?
one screen is the XP BSOD , crash screen.
seen here.
one other blue screen is "windows is doing updates" so let it??
one modern HP W10 screen 1 of 50
this is most times below a bad video card driver used on PC.
not matching card to OS. and bam crash.
Aug 28, 2017 | HP Hewlett Packard Pavilion Slimline...
My pc wont boot up normally, it has a blue screen show up but then it goes away before i can read it
The blue screen of death BSOD is set to auto-restart after an error you can change the registry to prevent this not sure if you can do this in safe mode but its worth a try you will at least be able to see the error.
Its a good idea to use MemTest on a boot CD to check your RAM for errors first then restore from an old image.
Feb 07, 2010 | Acer Aspire One PC Notebook
Cannot start in normal mode without blue screen popping up
Duing the startup, can you hit F8 just after the bios shows. You should see a list. If you choose, last known good configuration, what happens? If it blue screen's again, can you startup in safe mode? This is also a item on the list from F8.
Did you install any drivers recently, in the last day or two?
If so, when you boot into safemode, uninstall that driver and try to boot to windows normally.
Jul 28, 2009 | Acer Aspire One PC Notebook
I want to install windows xp on my acer 4230
Hi shaikh_shaha
Can you get it to boot using any of the options it gives other than boot normally? If the blue screen is caused by hardware then installing xp will still present the problem. If the blue screen is an operating system crash then using the recovery disk or doing a repair install will solve the boot problem.
If you still rather install xp then you need to go into BIOS and set 1st boot device as CD. To go into BIOS you will need to press F10 or F2 (usually) as displayed on the splash screen when you power on
Does this help?
May 02, 2009 | Acer Extensa 4620 Notebook
HOW CAN I FIX MY COMPUTER? ITS READING UNMOUNTABLE BOOT VOLUME?
You need your Windows XP cd for this fix.
Boot from the Windows XP CD and at the first prompt, press "r" for repair. Press 1 when asked to choose windows installation and then enter the admnistrator password. If you don;t have one, just press "enter" and it should show you "c:\windows>"
At this prompt, type the following
chkdsk /r
THis should take quite sometime but will fix the problem at the end. when you get the c:\windows prompt again, type the word "exit" and your system will reboot and load windows XP normally
Mar 07, 2009 | Dell Latitude D600 Notebook
Won't start completely
You have a virus I hope you have your data backed up. Reformat your hard drive(I assume you have a boot disk)
Dec 25, 2008 | Microsoft Windows XP Professional for PC
Blue screen error for windows xp prof
your operating system disk has a scratch or dirty, messed up data and has not installed the file
reinstasll
new hardware that fails will cause blue screen
Oct 16, 2008 | Biostar 945GZ-SE Micro Socket 775...
Sony VAIO PCV-RS530G PC Desktop Logo
111 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
