Question about Dell E197FP LCD Monitor
Dell E197FP LCD Monitor keeps turning on and off
My dad bought me this new monitor about 4mths ago, and its been great, but recently its been shutting itself on and off. Happens mostly when i'm using a program it will go black and the power light goes from green to orange then back to green, but the screen is still black, sometimes it stops when i press a button and sometimes it doesnt help at all. Iv'e checked my power managment settings and they are off and not set to put anything to sleep. any help?
  • 138 Answers
Re: Dell E197FP LCD Monitor keeps turning on and off
This is the way how to examine where the problem is. You have to check that you can see the image on screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons (Power on both cpu and monitor), there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken. They are easily replaced. If you cannot see any icon on the screen. I would say that there are some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or dark spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Posted on Feb 10, 2008
0 characters
3 Points
The stand of my E173FPs monitor is broken. What can I do?
Sorry to hear that the stand had broken on your monitor.
many times there is a mounting in the center of the monitor back that accepts a standard 4 screw mounting, which almost any brand monitor will fit on, many of these type stands will adjust in height and also sometimes rotate to a portrait if you should like to read documents with the narrow side to the top.rotated 90 deg. some monitors do not have this option the mount is called (VESA mounting holes, 100mm (Behind attached base plate) but eBay is a great course for this type of part. I should have one of the Dell original mounts in my older parts area. but i see (Problem with Dell E197FP LCD Monitor) and (E173FPs) both in this unsolved problems, and knot knowing exactly the broken area, not sure of all you need to repair the broken area in question. for personal help with this unit.
Dec 03, 2013 | Dell E197FP LCD Monitor
The monitor wont come on.i noticed the power button has been pushed inside the monitor and i need to know if i can disassemble it to get i tout without hurting the monitor
The E177fp and E197fp are identical units other than the size of the display panel. Here is a link to a repair guide for the E177fp that has videos showing how to open the unit. It should help you get your open.
Nov 07, 2012 | Dell E197FP 19 inch Flat Panel LCD Monitor
Does a Dell E197fp monitor have built in speakers
Not in the monitor, there is a sound bar that attaches to the bottom of the screen that is optional that added speakers to that model.
Sep 24, 2012 | Dell E197FP LCD Monitor
The monitor screen has a yellow tone to it.
try the new monitor with a different pc, if it works fine, your PC has a videocard problem..
May 08, 2010 | Dell E197FP LCD Monitor
E228WFP display disappears Posted by
disconnect all the cable from the monitor except the power cable .
see if you see any test screen and keep it on ,if the test screen blacks out you monitor is bad ,better buy a new one as usually repairs cud be expensive
Apr 17, 2010 | Dell E228WFP LCD Monitor
My new 21' flatscreen monitor keeps shutting off :(
Usually when an LCD display shuts off on it's own this can be a power supply issue. I would say if you checked all the connections you may want to contact the manufacturer. If it is only a few months old then you should be able to get it replaced under warranty.
Also, you may have an auto shut off feature enabled on the display itself. You may want to go through the display's menu to very that this is not the case.
Mar 08, 2009 | HP Pavilion F1703 17" LCD Monitor
ViewSonc VX924 LCD Monitor
Check the information at Viewsonic's website regarding their warranty:
If you have your proof-of-purchase and it shows the monitor is less than a year old, it would be covered. You would need to follow the procedure on their website to have the unit repaired or replaced, but it would not be your job to try to fix it.
Feb 11, 2009 | ViewSonic VX910 19" LCD Monitor
Dell E197FP LCD Monitor won't turn on completely dead
could be dead, but check to ensure that you are using the monitor ONLY, not TV tuner device. as a standalone, not hooked to cpu if there is no power light when plugged in assume your buying a new monitor.
Jun 21, 2008 | Dell E197FP LCD Monitor
Dell E197FP LCD Monitor Logo
524 people viewed this question
Top Dell Computer Monitors Experts
Brian Sullivan
Brian Sullivan
William Miller
William Miller
Are you a Dell Computer Monitor Expert? Answer questions, earn points and help others
