Question about Crosley CDG6000 Gas Dryer
Dyer won't come on
I have a cde7500w dryer and it was working fine and then would not come on, not the breaker, please help me
  • duck2 Jun 30, 2008
    I have a DG6000w dryer the drum want turn the door switch is new the belt on the drum has been replaced when i turn the machine on it will only buzz.
  • 27 Answers
Check the door switch. with the door open push the lever for the door switch. do you hear a faint click? if not you've found your problem. is the lever even there? if not you've found your problem. if both are o.k. lift the top of the dryer. you should see the switch mounted inside the front panel. remove both wires from the switch & put them together. make sure the wire ends are not touching anything. put the top down, close the door & try to start it. did it start? if yes, replace the switch. let me know if this helps
Posted on Nov 02, 2007
Why wont my matage dryer get hot
If you recently had a power failure or just installed your dryer sometimes its necessary to reset your breaker box. Unplug your dryer and turn off and then back on the breaker switch to your dyer. then re plug in your dryer and see if that works
I’m happy to assist further over the phone at https://www.6ya.com/expert/jaime_a0afdb97baa63a3d
Apr 27, 2014 | Dryers
No heat for whirlppol steam dryer
check the heater element, it may need replacement
Dec 22, 2013 | Dryers
Hi there,our dyer is not working at all..There is no power..I hope you can help us..
Try checking the circuit breaker feeding the dryer it may be tripped
Mar 02, 2011 | Kenmore 500 6952 Dryer
Whirlpool dyer will not work, have replaced the board but
Sounds like the control panel may be dead. If you cannot get any lights to come on at all on the front panel, its probably a goner. You can check the voltage coming out of the control pc board via the schematic inside the dryer panel. I have this same exact problem. I replaced the control board 3 times because the panel seems fine if i plug it into an external power supply but will not work when plugged into my dryer. I have my jumpered and running off of a circuit breaker. I have checked every part in the entire unit. That was over 2 years ago. I still need to get a control panel and see if it fixes mine but after dropping $130 on the control board, i feel i could buy another dryer with the $200 they want for the control panel. Also this dryer seems to streak my clothes with brown or rust colored spots. The dryer is spotless inside. I even took off the rubber seal because i thought the glue is what was possibly doing it when it heated up but that didn't help either....This dryer sucks.
Dec 21, 2009 | Whirlpool GEW9250 Electric Dryer
Kenmoore 80 series heavy duty (gas dyer) no heat.
If you still need help please post your model number. Gas/Electric?
Eric
May 25, 2009 | Kenmore 63942 Dryer
Dyer no movement/heat on stack unit- washer fine
It sounds like the dryer motor please change thanks
rate me
Apr 20, 2009 | Dryers
Dyer not heating
Could be the thermostat or over temp stat have failed.
If you are capable of troubleshooting electrical equipment, I can help you further.
Jan 30, 2009 | Whirlpool LEB6300 Electric Dryer
Water won't work but dryer does
Mine did the same thing and it ended up being an overloaded older breaker in the electric box. It would allow the dryer to work, but the washer was too much for it to operate. Had the breaker replaced with a new one and it works fine. Hope this helps!
Jun 14, 2008 | Frigidaire FEX831CS Top Load Stacked...
Dyer on combo won't start
This could either be a bad start switch or door switch
May 29, 2008 | Frigidaire GLEH1642DS Front Load Stacked...
Crosley CDG6000 Gas Dryer Logo
123 people viewed this question
Top Crosley Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
jasbo
jasbo
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
