Have the alternator removed and the slip rings on the rotor cleaned and machined . Replace the brushes and have the unit bench tested . When this happens it is an indication that the brushes cannot maintain contact with the slip rings either from lost spring tension --dirt on the rings and rings badly scored
SOURCE: my 2003 Tahoe will not start without a jump.
there is a short circuit somewhere which is chewing up d battery...hope u didnt put an amp or capacitior lately or installed a radio...check d wires again
SOURCE: 2003 tahoe idles rough and stalls
might want to check your mast air flow sensor. if your check eng. light is on have the codes downloaded
SOURCE: 2003 tahoe electrical problems
check fuel regulator - air intake sensor - brake cylider problems
SOURCE: Remove alternator chevy tahoe 2003
You have to remove the belt.Also you can have it tested on the vehicle.Once you have the 2 bolts off and the belt the alternator should come off.Good luck.
SOURCE: 2003 TAHOE BATTERY NOT CHARGING
How old is the battery...???' Had the same problem with my '89 Cherokee, and it was a faulty battery...Was making some kind of internal shortcut, and didn't accept charge...
Cheers.
