Hi mike harris,
i think your TV is on demonstration mode.
To turn off the demo mode, press and hold the HOME or MENU button on the TV for more than 10 seconds. The messageDemo mode: Off will appear on the screen.
NOTES:
SOURCE: PC input to Sony Bravia - from Sony Vaio Laptop - unsupported sig
Hi Julie,
There are a couple ways to go here. I'll give you the procedures step by step. If you want clarification on anything, just ask. If I make an assumption that is wrong, stop me and let me know. The more you know, the easier this will be for both of us.
First I'd like to double check on MisterSony's diagnosis. Refresh rates that are too high end up as a black screen on many LCD models.
This is my first assumption, the display settings are currently for both monitors. Your original screen is still functioning.
If so,
Get back to me with the results. If it was already set at 60Hz. We go to the next step.
Mike
SOURCE: I can't get rid of the information bar across the top of my TV
Press " i " (information) button on TV remote and on-screen display will disappear.
SOURCE: Sony Bravia 40inch LCD Digital TV
Its very easy, pick TV original remote and press " i " (info) button on remote and on-screen display will disappear.
Have a great day.
SOURCE: sony bravia lcd
Sounds like a possible T-con board failure. Which would need to be done by experienced tv repairman
SOURCE: have horizontal lines across the screen and some
Yeah we have the same exact problem here. Defective TV....ours would correct itself after 30 mins, but now it's blurry all the time. I'm never dropping 2K on a SONY tv again.
Sony® created BRAVIA® Theatre Sync™ to go beyond basic digital audio and video transmission. Based on the HDMI-CEC function, BRAVIA® Theatre Sync™ will be included on select BRAVIA® Theatre home A/V systems and components. This useful function reduces the hassle and time consuming job of powering up, routing signals, etc. to the simple push of one button.8 Want to play your DVD on your Sony® A/V system? Easy, just push PLAY on the BRAVIA® HDTV remote and everything is taken care of for you. Even when the system is off! Want to change from TV sound to digital surround sound through your Sony BRAVIA® Theatre A/V system? Just one push of the Theater Sound button on the remote and voila, surround sound through your system. Want to power down everything once you've finished enjoying it? Push one button and the TV and A/V system powers down. BRAVIA® Theatre Sync™ helps make things a whole lot easier to operate.
