NexxTech 4318570 Corded Phone Logo
J
John V Posted on Mar 02, 2014
Switch nexxtech 4313449 from rotary to pulse - NexxTech 4318570 Corded Phone
2answers
Is it possible to call out with this phone,it has an old fashion dial
I assumed your old-fashioned phone works in Pulse (Rotary) mode only. Maybe the Tel Company or the Private Tel Exchange in your house supports only DTMF (Dual-tone Multi frequency) or MF (Multi Freq.) tone.
1helpful
Change pulse tone rotary
To change between pulse and rotary, from an administrator handset press MENU-9-1.
I have a Caller ID Big Button Speakerphone Model 4313449. The manual has been lost. I am trying to increase the number of rings before the answer service clicks in. Can you help me?
Well, the manual doesn't say anything about changing the number of rings before it answers, so I doubt you can.
Click here for the manual.
If you think you should be able to, maybe customer service can help: 1-866-363-3059
Model UNIDEN UCIS-225 - Phone suddenly dials like a rotary phone. Does anyone know how to make it return to the non-rotary dialing?
two places<br /> 1. Manual switch on back of phone Tone or Pulse<br /> 2. Menu-Set Dial Mode - DTMF (tone) or Pulse
3helpful
Hi there --- just need the user manual for Nexxtech Caller ID Big button speakerphone model 4313449. Am simply trying to find out how to delete an caller from the display OR how to delete all calls. Mnay...
You can download the complete user manual by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view this manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
Getting the phone from rotary to touch tone
there should be a switch somewhere on side marked pulse/tone, move it to tone
Dialing sounds like rotary and will not allow extension choices
Since you neglected to specify the model of your VTech 5.8GHz phone I can only suggest you enter it into the search box here to download a copy of the manual to see how to switch from pulse to tone dialing.
6helpful
4answers
Ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
10helpful
Polycom Sound Station
SoundStation: Changing dialing from Tone to Pulse
http://knowledgebase.polycom.com/kb/search.do?cmd=displayKC&docType=kc&externalId=10966&sliceId=SAL_PUBLIC_1_2&dialogID=979138&stateId=0%200%20977279
Description
sp.gif sp.gif There are three ways that a SoundStation can be changed from tone to pulse, which depends on when the unit was manufactured.
1. Pressing the Keys 3&Vol + simultaneously, will toggle between Pulse and Tone while the unit is in On Hook Mode (off).
2. Pressing the Keys *&MUTE simultaneously, will toggle between Pulse and Tone while the unit is in On Hook Mode (off).
3. Operation done by DIP switches. Dipswitch Configuration On the bottom of the SoundStation, in the lower left hand corner of the large sticker may be a small silver sticker. Underneath that sticker are 4 DIP Switches. Switch number 4 is for tone and pulse,ON being tone, and OFF being pulse. Do not change the other three swithces as this could render the phone inoperable.
Top NexxTech Lands Phones Experts
k24674
Are you a NexxTech Lands Phone Expert? Answer questions, earn points and help others
