REAR UNSCREW THE UNIT PULL IT OUT TWIST THE PART THAT HOLDS THE BULB HALF A TURN PULL IT OUT REMOVE BULB REPLACE WITH SAME NUMBER BULB.
FRONT BULB CHECK TO SEE IF YOU CAN ACCESS SIGNAL FROM BEHIND UNDER THE HOOD. IF NOT REMOVE THE LENS BY REMOVING THE SCREWS AND ACCESS THE LIGHT THAT WAY. PUSH THE LIGHT BULB AND TWIST IT IT WILL POP OUTBECAUSE IT IS SPRING LOADED. ALWAYS MAKE YOU SURE YOU CHECK THE NUMBER ON THE REPLACEMENT BULB TO AVOID HAVING TO DO THE JOB TWICE/
