Question about Akai PTH5498 54" Rear Projection HDTV-Ready Television
Curves in the top and bottom of screen.Picture image is discolored.
  • Anonymous Dec 02, 2007
    convergence problem
  • 934 Answers
The convergence amps have most likely failed and taken with them the +/- 30v line. Your unit takes two STK392-040 Sanyo built Ics at board location Icz103 and Icz104 and usually one or more pico fuses and some low ohm resistors. F1018 sometimes opens due to stress but generally it's just the two 6.3 amp pico fuses and if they have opened I strongly recommend replacing them with a 6.3 amp slo-blo pico.
The low ohm resistors at RZ147, RZ146 usually show signs of heat stress and may even be burned beyond recognition. Testing at that point is almost unnecessary but will confirm their change in value. Almost always they need to be replaced.
A quality shop will have this unit back on its feet in no time - faster if they have the parts in-stock, which you might ask about when you shop around for a good repair facility.
Have a great day!
Bill
Posted on Dec 03, 2007
Why does my TV show discolored vertical bands and can I fix it at home?
The T-con board controls the picture elements on the screen. Usually replacing this board will solve the problem. If you can touch the screen and the lines disappear and later reappear, that says the screen itself is defective. The only fix is to replace the entire screen.
Oct 10, 2015 | Hisense F42K20EGB 42" LED 1080p 60Hz
The picture is curved at the top and bottom and it blury
its good that you give it to an expertise to handle it.....but if u insist and costly, open the back cover, their should some adjustments keys their that helps in adjusting images...one for the 3 colour (blue,Red,Yello) and one for sharpening pictures (making it clear)....for safe use give it to an expertise to minimize further faculties
Oct 04, 2009 | Televison & Video
Curved/warped and completely out of convergence Image
Sounds like you need the convergence amplifiers replaced. Cost approx. $300.00 for expert to repair.
Jun 20, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Curved picture at top and bottom
if it is bowing from top and bottom your looking at a convergance problem if you keep using your tv soon there will be no picture at all when the board crashes... convergance board needs to be replaced... hope this helps..
Apr 11, 2009 | Samsung HCN4727W 47" Rear Projection...
RCA 56 inch hdwidescreen
Did you use the Automatica Convergence to try and straighten it out? If that does not help, you can manually adjust the convergence.
Jul 12, 2008 | RCA HD56W58 56" TV
Mitsubishi VS-4561 picture curved inward
Its Your Convergence Chips!. And Maybe a few Resisters!. Common Problem with this kind Of Set!.....
Jun 30, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-60111 picture distorted
how do I manually switch my t.v. from 480i to 1080i on dtv with remote.
Dec 31, 2007 | Mitsubishi VS-70707 70" Rear Projection...
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Screen is distorted on the top and bottom
Loose connection on convergence board, you could tapp and should go back to normal, find loose conn. and solder back.
Sep 09, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Akai PTH5498 54" Rear Projection HDTV-Ready Television Logo
52 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
