ZTE Score Logo
B
Brittany Mundorff Posted on Mar 01, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Everything works on my ZTE savvy but when I set my ringtones for texts or notifications it only vibrates an the sound is up all the way i need help please this phone is 2 if not 3 weeks old.
Tom Carson
Level 3:
  • Master 3,083 Answers
  • Posted on Mar 01, 2014
Tom Carson
Master
Level 3:
Answers
3083
Questions
0
Helped
684260
Points
8555
Best thing to do is take it into your provider, and see what can be done.
Testimonial: "The bad thing is is its on pre paid not contract."
1 Related Answer
Anonymous
  • 61 Answers
  • Posted on Jan 15, 2013
SOURCE: need to unlock my metro zte phone
If forget the password to unlock X500, you can refer to the following method, which can reset the phone and erase all the user personal information.
1) First power off the handset, press the Power on key + Camera key + Down volume key together at the same time when restart the handset.
2)When display "ZTE", press the Menu key at the bottom of the screen;
3) Choose "Wipe data/factory reset" through volume key
4) Press "Camera" key to confirm the above item
5) Choose "YES...delete all user data"
6) Choose "reboot system now", handset will be restarted automatically and all the user data will be erased.
tip
How to Fix iPhone Not Vibrating?
If you are in a meeting or attending a special event, you probably set your smartphone to silent mode to avoid any distractions from your phone. But what if there is an emergency? You will miss the calls and texts from your phone and then regret it later after realizing that it is a very important matter that needs to be discussed with you.
If you don't want to disturb your meeting or the people around you when your phone receives calls or texts, then choose to vibrate mode instead of silent mode - at least you will be notified if your phone receives any notifications. But what if you are using an iPhone and you learned that the vibrate mode is not working. What would be the reason behind it?
/uploads/images/fix-iphone-not-vibrating-undefined-undefined-0.jpg
Fix iPhone not vibrating
Now, if your iPhone is not vibrating when it receives calls, texts, notifications, or when you switch on the ring or silent mode, then you need to learn some of the solutions to fix this issue. Here are the 3 effective solutions that you need to know.
Solution 1: Check the iPhone Vibration on Sound and Haptics Settings
One of the basic things that you should learn about your iPhone is how to set the phone settings, especially the vibration mode. If your phone is not vibrating, go to your iPhone settings then navigate to the sounds & haptics option and check the vibration mode from ringtone to text tone - if off, turn it on. Then disable the focus mode that restricts the vibration of the app's notification.
Solution 2: Check the iPhone Vibration on Accessibility Settings
After enabling the vibration in the sound and haptic settings but still your iPhone is not vibrating, then go to the accessibility settings and check the vibration mode is turned on.
Solution 3: Fix iPhone not vibrating via iOS System Recovery
If the first two solutions didn't work on fixing the vibration issue of your iPhone, don't worry. With the iOS System Recovery, all iOS errors will be fixed including the vibration issue of your iPhone. This reliable tool can quickly solve any type of iOS error.
on Jul 14, 2022 • Miscellaneous
How do I change ring and text tones on my Pixi Alcatel One Touch
hi Jo.
this is all i can find at mo.
  1. From the home screen, tap the All Apps icon.
  2. Scroll to and tap Settings.
  3. Scroll to and tap Sound & notification.
  4. Tap Default notification ringtone.
  5. Tap the preferred notification sound and then tap OK.
Change the phone ringtone and notification sound on your Alcatel ...
devicehelp.boostmobile.com/.../ONETOUCH.../Change_the_phone_ringtone_and_notifi...
if this does not work then go to this link might help you out some more.
How do change ring and text tones on my Pixi Alcatel One Touch Google...
1helpful
How do I get my Cell phone out of Silent mode?
Go to settings. click on sound and in the sound section you will be able to choose silent mode vibrate mode or loud.
Zte problem
This happened to me too on a zte majesty. I followed someone elses advice and went in to my main settings (not the one in the sms folder) and reset it there and its worked ever since. I think the zte website addresses this exact issue if u need more help. Good luck.
Mar 10, 2014 • Cell Phones
Zte merit z990g does not show icon or sound, message alert
For Message alert first,you should build a folder named notifications and copy the ringtones that you want to use to the folder second,enter into message interface, click Menu key, click (setting), and (Select ringtone) interface will appear, then you can (set message ringtone) by selecting ringtone.If you are still facing difficulties finding a solution contact ZTE they will walk you through the process.
1helpful
2answers
I've tried everything, can't get sounds for in coming texts
go to your settings. click on sound. here you should find a notification option and set which ringtone you would like. make sure that you go back to your sound settings or caller settings to make sure the volume is actually turned on for incoming text messages. the reason you might not be getting them is because you have it default in your phone to keep them silent. just browse your setting options for sound or calls where you will find a "volume" option. select that and slide your notification sound over to whatever level you like! hope you found this helpful!
Dec 29, 2012 • ZTE Warp
No sound when text message arrives
Ok, here's a way: start the 'Text messaging' application. Then, go to 'Menu > Messaging settings'. Slip down and tick the 'Notifications' checkbox. Then, click on 'Select ringtone', in order to choose the way you want to be notified. You can also tick 'Vibrate'. After you finish changing your settings, press the back button.
Hope it works for you.
Anyway, please, let me know if I can help you any further.
Regards,
Carlos
3helpful
2answers
HTC Touch doesnt ring on incoming call
Hi. First thing, you can check your sound settings, by tapping Star Menu, then Settings, then Sounds & Notifications, and through that page, you can check if your incoming call alert is on (just sound, or vibrate and sound), you can try to change the ringtone to see if your current ringtone is damaged or not. (Since other sounds are alright, there shouldn't be any problem in your hardware or in the sound volume levels) Hope this helps.
Top ZTE Cell Phones Experts
vince
nexrad_chris
Paul Carew
Are you a ZTE Cell Phone Expert? Answer questions, earn points and help others
