Question about SanDisk Sansa E280 MP3 Player
Help with sandisk sansa e280
I plug my player inton my computer and when its connected it says I need to free room up even though when i look through i have 0 files.  I cant use it for music or anything
  • AXEL_CLYDE Nov 04, 2007
    I also have the same problem as when i plug my Sansa e280 into my P.C, it tells me to free room and when i later switch the sansa on, it reads in a box, 'Not Enough Space for music DB. Please free 6MB' . But i havent got any files on it. PLEASE HELP!!!
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
Can not find a free manual for my sandisk sansa e280 mp3 player
You can go here and read this manual and even download it: http://static.compusa.com/pdf/Sandisk-e200-Series-Manual.pdf
It is for all 4 models of this kind.
Apr 19, 2009 | SanDisk Sansa E280 MP3 Player
My Sansa e280 won't turn on
Hold down the menu bottom for about 20-30 secs. Should power back on.
Mar 17, 2009 | SanDisk Sansa E280 MP3 Player
My sansa E280 will not turn on
I have more advice on my Tips & Tricks for fixing Sansa players, but here is a likely candidate:
Download the Sansa Recovery Tool from Sandisk's website (make sure the Sansa is not plugged into the computer yet). Once the Recovery Tool is downloaded, connect the Sansa to the computer while holding in the REC button and continue to hold it even after th player is plugged in. It should go into Recovery Mode in 10-15 seconds or so.
-Tha Mp3 Doctor
Jan 17, 2009 | SanDisk Sansa E280 MP3 Player
Sansa plugged into Ipod music player - won't work now
Yep - it's a sad thing. iPod docks have ruined many a good mp3 player. Download the Sansa Recovery Tool from Sandisk's website (make sure the Sansa is not plugged into the computer yet). Once the Recovery Tool is downloaded, connect the Sansa to the computer while holding in the REC button and continue to hold it even after th player is plugged in. It should go into Recovery Mode in 10-15 seconds or so.
-Tha Mp3 Doctor
Jan 06, 2009 | SanDisk Sansa E280 MP3 Player
Frozen
-Tha Mp3 Doctor
Dec 19, 2008 | SanDisk Sansa E280 MP3 Player
Mp3 wont play downloaded music
The device has 2 modes on it MSC and MTP, if you changed modes and uploaded songs in the other mode, they are only visible on the PC in that mode. But, the PC will show the total amount of free space on the device.
If this is not the issue, I would try formatting your device to remove everything and start over.
You can FORMAT thru My Computer>Device Name (e280)>Right Click and select FORMAT.
Best of Luck.
Please RATE my solution BELOW.
You can also add to this question for additional support.
Nov 22, 2007 | SanDisk Sansa E280 MP3 Player
Sansa e280
Cannot correct - sorry
Nov 06, 2007 | SanDisk Sansa E280 MP3 Player
Need help quick with sansa e280
try switching your usb mode, do that by going into settings, this might help but im not sure
May 28, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
80 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
