The resolution of your TV is over 720 pixels per inch (PPI)
The Nintendo Wii console can only handle 480 PPI
You may need to buy the adapter to hook the console to the HD components (R/G/B) instead of the standard composite (Y/R/W)
Here is one for cheap on Amazon:
480p HD Component Cable for Nintendo Wii
- Matt
SOURCE: i have hooked my wii up to a new samsung 42"
Make sure that you have switched the Wii to component video in the system setting menus. Once you have done that, you should have a color picture in 480p! Hope this helps!
Testimonial: "thanks man i was goin crazy tryin to figure it out you guys rock "
SOURCE: Wii is in black and white rather than color on Samsung?
change the wii-tv connecter. please vote.
SOURCE: Hooked up my Wii to a new TV, Now color is bad
I suspect you have it hooked up wrong check, Color to color, this is what can make it green, if not that then ensure your format is ok either PAL or NTSC, check.
You should order an hdmi cable for the WII so that it will connect. Right now you have audio (red and white) and video (yellow) the new television sets dont use that anymore.
everything is hooked up right, but when i get to settings to change it to hd tv, it wont let me
