2008 Chrysler T&C makes a humming noise driving straight and gets louder when turning left. Replaced pads and rotors and wheel bearing, still making noise. What is the problem?
SOURCE: noise in front end, sounds
You say the rear wheel axles and bearings have been replaced, you mention nothing of the front wheels, you have the symptoms of a front wheel bearing being worn out, remove them and check for pitting in the bearing rollers or the bearing races, I am sure you will find a problem. Hope this helps solve your issue with the bearing noise.
SOURCE: Alero loud humming/roaring sound coming from front end.
That's indicative of a wheel bearing, which is why you were told to change that out. However, it's also possible that the carrier bearings in the differential (where the drive axles attach) have gone bad. That happened to me on my 300ZX several years ago, and I had to replace the diff bearings. I would have them checked out somewhere other than a dealer (you'll probably get a better price from an independent shop).
As a sidenote, to be sure it wasn't a wheel bearing, if you hear it quiet down in a turn one way but get louder in a turn the opposite way, it's likely the wheel bearing. If you turn left at speed and it gets louder, then it's the right bearing (since you're loading up that side of the car). If it gets quieter in a right turn, it's the right side (you're unloading that side of the car and not putting as much weight on it, so it doesn't drag as badly). See if you get that symptom just to be sure that the wrong side front wheel bearing wasn't changed.
SOURCE: Growl noise while driving
Sounds like Your Power Steering Pump is on it's Death March. Replace it and your Problem will go away.
SOURCE: Humming noise comming from front left wheel area of 03 Sebring
it may be just sound of uneven wear of tyres
