TEAC CTV 1- I have tried to replace the original Remote with other universal Remotes some cheap ones and I have tried alot of dearer ones and do you think any of them can learn or find the right FREQ well no. I have been told by Teac themselves that the remote is still get able but you have to go through Speedy Spares??? I have found a universal remote can be used on many CTV's and I have done it, so whats so special about this model??2- the other thing is, it's just gone down with no Horizontal drive? I have replaced the normal fault causing problems for this make and model. Large Cap's, and a couple burn't Resisters and fixed the track but still no luck, looked at the transformer to see if the windings were open but, and to me the output of the Horizontal checks ok, so?? If you have any suggestions, why you say it belongs to a 79 year old that can not afford a new one?? And cricket starts soon and we have all done this for people. Thank you Paul Robinson PR Electronics
  • 140 Answers
SOURCE: TV won't respond to ANY remote control
You need to change the I/R receiver on the front panel pc board (which can be popped out of the top front of the tv on the plastic key panel without removing the back cover) Location# IR13401 Part# 245282
Posted on Aug 21, 2007
  • 72 Answers
SOURCE: Which brand of universal remote control works for WEF2702 27" TV?
Try to call the phillips costumer service first!
Posted on Nov 11, 2007
SOURCE: orion tv
Hi Gerald P, just posted we experienced same problem. Few minutes later my husband has finally solved our problem. Don't know whether you can try the same. We had an old FOXTEL remote, got onto FOXTEL site and instructions how to program remote to control TV.
Dowloaded instructions with code for TV (after trying a few tries, the fifth code solved it). FOXTEL control needs to be programmed with the code suitable to TV. By pressing "ON", "AV", Red button and Select (at same time) then put code in. Turn "OFF" then "ON" see if code complies. If not try another one until you get it.
By using the FOXTEL remote on the "AV" you can change the channels on the TV and adjust volume up or down as well.
Hope this can help you in your situation. Glad we are up and running again. Bye
Posted on Jan 27, 2008
  • 104 Answers
SOURCE: teac wide srceen is small and bent on sides
Not positive but I think the model number is CTW2850S.
You can get the Manual in PDF format Here.
A picture getting smaller and bent inward indicates there are bad capacitors on the main circuit board inside the set. Unfortunately there is no code to fix this type of problem and it needs to be serviced by a qualified technitian.
Posted on Mar 12, 2008
  • 4 Answers
SOURCE: Remote controls will intermittently work
Just repaired a friend's Toshiba 36inch 200 lb heavy with exactly the same problem.
The receiver inside the TV was the problem and getting to the screws holding the module board in are extremely difficult to remove. Watch the crossover connectors that attach between module boards as they are very delicate. Damage them and you maybe S.O.L.
Part cost $18 including shipping from
Posted on Apr 02, 2008
Need 4 digit code for Teac tv and all for one remote
You can use code search to find something that will work. If a search through all codes stored in the remote fails, you my have to try a different universal remote. All universal remotes do not store all possible codes.
Mar 14, 2017 | Teac Televison & Video
Code for universal remote
There is no true 'universal' remote since new code sets are being created all the time and a remote that was designed two years ago cannot contain newly created codes.
Before buying a remote, it's wise to go to the maker's site to see if it will do the job you want.
If an original remote has died, and you don't want to toss whatever electronics for which it was made, go to the linked site below; they offer the broadest line of real originals or tested 'universal' substitutes.
Not cheap but great inventory:
1 800 Remotes Factory original replacement remote controls
Jul 05, 2015 | Universal Televison & Video
I have telefunken Vegas 127cm plasma tv model no: VPM-500FHD. Can someone help me with a "one for all 4" universal remote code? Pretty pretty please.
You might check at the link below for a code but nearly all 'universal' remotes really aren't universal.
Before replacing a failed original remote, get makes and model numbers of those you have seen, then check on line for the code tables to avoid buying one that will not work with your gear.
Jan 09, 2015 | Universal Televison & Video
Would any one be able to recommend a universal remote control that would work on a Centrex CTAR70GW split air conditioner? Thanks
Even if you find one you would need an original remote to program it .
You could try a cheap Universal TV remote if able to program with an original one .
Nov 22, 2014 | Heating & Cooling
yes, you can get an original, or buy a learning remote and teach it to be your teac remote.
Alternatively why not let a friendly tech see if they can refurbish or improve the original
TEAC LT1 Remote Control
Estone Brand New DC 3V Mini Learning Remote Control RM L7 Universal
Caikote Conductive Coating Key Pad Repair KitMCM Part 200 315Caig...
Jun 27, 2014 | Teac LT-1 Clock Radio
Availability and cost of replacement remote RL611??
Try website like to buy an original remote or compatible to it.Around $30-$35 dollars for the original or very close to the original remote.Don't attemp used univeral remote on this brand Sampo is very small company and market share in the electronics devices,probally have no universal codes for this product.If u plan to buy those cheap unniversal remotes,by those eclectronic's stores or big box stores,for a after market universal remotes devices.
Feb 07, 2011 | Sampo DVE-611
My grandson broke my original remote control for my toshiba tv how do I program a universal remote to work
In the manual it self,give all the codes for ur tv,none of them work?No,one well give u any other codes will work for ur tv.Return the Universial remote.Try this website like to buy a original remote.Yes,it cost alot more than a universal remote,but it ur tv original remote.
Jun 29, 2010 | Televison & Video
How can i get a new remote for this tv?
Buy a universal remote and use this trick: On most universal remote control, you will find the procedure to enter the builder code OR a procedure to pass through all the code of the remote, one by one and pass to the other TILL you find the right one. It happen to me numbers of time because all my family ask me to do this...
Sep 23, 2009 | Disney 13" TV
Original remote control very expensive, possible universal one?
If you want to ring me i can help if your in the UK
0871 597 0097
Marc Engineer
Apr 04, 2009 | Sanyo PLC-XU41 Multimedia Projector
Remote is no longer working
i need a universal remote that can work for a jwin dvd player
Feb 03, 2008 | Jwin JD-VD502 DVD Player
Televison & Video Logo
Top Televison & Video Experts
