Question about Mitsubishi WD-62825 62" Rear Projection HDTV
Mitsubishi wd-62825 dlp
Mitsubishi wd-62825 tv dlp        what causes a green light on front of tv blinking fast on and off and tv will not turn on
  • 11 more comments
  • Denns Nov 04, 2007
    I had the chasis replaced twice. After the chasis has been replaced the tv works for about two days and then the green light starts blinking again. I get a green screen with black vertical lines then the TV shuts off. I can get it to turn back on by the reset button or unplugging the unit. This works for up to 1 hour then it shuts off again. The fan always runs. I heard this tv has a problem with the DM capisitors. please let me know what my options are. The service person is not reliable
  • Anonymous Nov 10, 2007
    mitsubishi wd-62825 will not turn on green light blink.could not reset. tried unpluging,
  • Anonymous Mar 09, 2008
    I have the dame problem: continous flashing green light. We have been
    without a TV since Dec. 31, 2007. The repairman said it needed a new
    chassis. Now he says the chassis are no longer available. He is
    currently waiting on a new board which was supposed to be in on Feb.
    18, 2008 and has now been pushed up to March 15, 2008. We paid $5500 for this TV in Dec. 2004 and have insurance but don't want to have to wait forever for it to be fixed ...IF IT CAN BE FIXED!!!
  • michael zummo Mar 28, 2009
    I have a similar problem with 62 inches dlp but my blinking green lights do not stay on. it only blinks for about 70 seconds and then nothing no power up
  • simbak95 Mar 28, 2009
    Our green timer light keeps flashing and we can't reset it. We've unplugged it, hit the reset button, removed the cables that connect it to the cable box and then re-attached them and the light won't reset. This happens all time and it takes days to come back on. Help!
  • Anonymous Mar 17, 2014
    Mitsubishi Wd 92480 TV won't turn on
    When turn on Mitsubishi WD - 65732 DLP TV green pwower light comes on, then after a few minutes the status light turns red. Unplugging and replugging the tv did not help.
    model 62825 green timer light blinking
  • Anonymous Mar 21, 2014
    tv keeps blinking snd shuting off
    I turn my tv on and after like 15 minites it starts to flash and turns off
  • Anonymous Mar 25, 2014
    Wd-73738 mitsubishi dlp the green light come on but after 2 mins there a red light flash 6 times and amber light flash 1 time
    the screen is black the power light flashes green fast but after a while turns red
  • Anonymous Mar 30, 2014
    no power
  • 934 Answers
The WD62825 has a Digital Module located on the left side of the chassis looking at it from the rear of the set. It's housed in a metal box that can slide out of its holder after removing the trim screws.
The module has its own power supply board and there are a group of 16v/1000uf caps on that board which commonly fail causing the constant flashing standby light. Further back on the module is a small board about the size of a matchbook called the E2P module. Its SMT (Surface Mount Technology) caps also commonly fail which can cause the same symptoms. Techs can tell whether the E2P has failed by simply removing it, hooking the DM back up and trying to power the set. If it powers on the picture won't be much good - but at least you can tell what's keeping it down...
Back to the caps on the pwr board. If they've failed they usually will buldge visibly on top. And ESR is almost not necessary. In any event that's the nuts and bolts on this model.
Is it a job for a layman? Yes and no - you might strongly consider a tech if you don't feel comfortable removing all the connections that the DM has with the signal board. There are about six - multi-pin - wired connections to unplug and then sliding the DM out of the unit and carefully removing the screws and latching to take the DM top cover off...
Hope this helps.
Bill
Posted on Nov 10, 2007
The TV will not come on and the light just keeps blicking. What is the problem?
Posted on Sep 19, 2008
We have dlp tv model wd-52825
this tv is blinking green light constantly wont power turn on key switch dosent work
replaced capacitors in power/signal/dm/ fmt/terminal board but still green light blinking
i checked power pcb
a.stand by power ok(tp30v,tp12vs,tp6vs,tp+15v,tp-15v)
b.main power dosent work(pon-2 power on voltage not come in from micom)
do you have other solution please contact us
thank you
myong west
Posted on Sep 10, 2008
  • myong west Sep 10, 2008
    we need more solution
    we add comment (upper line)
    we need your answer
After replacing bulb on WD-82738 still not working
How to replace the lamp in your Mitsubishi TV - YouTube
? 3:13
https://www.youtube.com/watch?v=_ONPuB5L-x4
Nov 1, 2012 - Uploaded by Mitsubishi3D
Your Mitsubishi television is powered in part by a 180 watt lampthat illuminates your TV's vivid colors. ... The first time they delivered my TV it was broken. ... I just barely got myreplacement bulb in today and it still only blinks orange light. .....I was watching my mitsubishi 73 3d model wd-73740 and ...
After replacing bulb on WD-82738 still not working - Fixya
www.fixya.com/.../t26028385-after_replacing_bulb_wd_82738_still_no...
6 mins ago - after replacing bulb on WD-82738 still not working bulb went out and burning smell. Replace the bulb, turned it in - Mitsubishi WD82738 82 ...
Mitsubishi WD-82738 Blinking Green Light - Tom's Guide
www.tomsguide.com/.../id.../mitsubishi-82738-blinking-green-light.html
Jan 12, 2015 - I have a Mitsubishi WD-82738 with the blinking green light of death as I have seen it called. ... Sounds like you replaced the parts, and it still is not working.... It would not work for us if we did it after the blinking. ... overnights. an ive already t akeing out the bat Forum; blinking green light changed bulb help!
Amazon.com: Mitsubishi WD-82738 DLP TV Asse
Dec 29, 2015 | Mitsubishi WD82738 82 1080p 3D DLP Home...
Blinking Green Light on Mitsubishi DLP 52525
the circut that detects the bulb has been also failing in these sets
and the conversion chip that controls the picture , and the transformers are not putting out the full power they are supposed to.
this set will need to be tested to determine the exact cause or causes
Oct 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62526 turns on-n-off
I would bet the illumination lamp has reached the end of it's life (~$40 online). Should be easy to replace. Also possible the ventilation vents need cleaning, which could cause the lamp to overheat and turn off.
Dec 12, 2013 | Mitsubishi WD-62526 Projection TV
Green blinking timer light, TV won't turn on
Common to mitsubishi dlp tv's,you have a bad signal ***'y (power supply,formater board) lots of bad electrolytic capacitors,
Mar 22, 2010 | Mitsubishi WD-62525 62" Rear Projection...
If the green front panel LED blinks continuously and the TV never comes on, its an issue with the "DM" board. When these TVs are first plugged in, the green LED should blink for 30 sec. to a minute or so. This is the TV booting up, reading its software. Mitsubishi has been having problems with this circuit for several years. In may cases the only permanent solution is to have the chassis rebuilt by Mitsubishi at considerable cost and inconvience. The chassis may have to be sent back to Mits for this rebuild. Call Mits and ask for help.
michtech
Feb 13, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Wd-62825 mitsubishi dlp tv
Had the same problem. Service replaced the lamp engine. It did help.
Dec 18, 2008 | Mitsubishi WD-62825 62" Rear Projection...
Mitsubishi WD-62825 Green Blinking light and TV won't turn on
I have the same problem with the green light blinking and the T.V will not come on. I have reset it and unplugged it and everything and still nothing. Can anyone help me
Aug 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
No problem, do self diagnosis test, read threads here or goto ctechnicians.com get error codes first and get back with me.
Dec 17, 2007 | Mitsubishi WD-62825 62" Rear Projection...
Mitsubishi WD-62825 62" Rear Projection HDTV Logo
2,149 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
