When I try to connect my Philips SH9100 Hadphone to Windows 8 by bluetooth connection, simply I can't maket it. By other hand trying that in my Samsung Galaxy S cellphone, it works properly with no stresses. I've tryied to find a drive on Philips site with no success. Thaks for help.
SOURCE: hooking up computer to philips 60pp935217 AV5 HDTV connector?
Hi Roger,
Initially, pls try lowering the screen resolution of your PC. This can be done at the Display Properties/Settings tab and then move the slider of the Screen resolution towards the left, Apply OK. In some instances, you need to also lower down the Screen refresh rates in the Monitor tab of the Advanced Properties.
If your concern has not been corrected after completion of the above procedures, then other methods can be considered.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
SOURCE: Connection problem for Philips VOX130 with other bluetooth devices
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.
2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select VOX130 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
SOURCE: Philips SPC 1300NC not installing on windows xp
Uninstall all drivers reinstall from cd then put camera in different usb port than the one previously used lol i have this cam and have it installed on xp pro no issues
SOURCE: Philips SAA7130 TV tuner not scanning channels
hi try this procedure
1.go to device manager
2.then double click sound,video and game controller
3.then right click on saa7130 tv card (which is the driver u should have installed earlier)
4.then right click on that and select update driver software
5.the option box appears select browse for driver software on my computer
6.next u get two option select second one i.e let me pick from a list of device drivers
7.then u fine two collumed table manufacturer and modle.(note:uncheck show compatible hardware)
8.then under manufacturer select philips semiconductors then from model select saa7162 ,hybrid capture device and install.
8 it may warn about windows signature..some thing like that but dont worry just continue
9.it installs the driver.
10.then restart your pc
11.on windows startup it may show error like no device some thing like that .u just run ur tv application
if it works the dont forget to tell thanks
if it dosnt the sorry for wasting ur time
