Recently hot a pothole, 2004 ford focus svt. Kyb strut. This has happened before but in Colorado it's nearly impossible to do. When looking at front right tire it is going inward. My tire wasn't damaged on the slow drive home. I didn't break anything but I won't drive it anymore till I know what needs to be done. Low on funds so will a front wheel alignment fix this issue or did I just jam the strut?
I suspect you damaged the lower track control arm ,cheap repair as they are about 40 euros complete ,this is why i like my fords CHEAP SPARES ,i doubt if you have damaged the strut very much but the track control arm ?? This is all you should need to change you should not even need to re-track it either
SOURCE: I am always replacing front tires due to alignment
It sure sounds to me that the gentleman or lady in charge of aligning your vehicle wasn't doin the job properly.The entire vehicle's suspension needs to be checked for visible damage or worn out parts before the alignment.Had this been done then they would have seen why the back tire is leaning in like it is.I suggest that you take the vehicle elsewhere.....just for your safety alone.You do not want to be driving a vehicle whose suspension may fail at any time and put you in harms way....HOPE I COULD HELP!!!
SOURCE: back right wheel tilts inward. strut broke or
It could be a damaged strut but if it hit a curb it would more likely tilt out. Some of those had an eccentric bolt that allowed adjustment of the camber. Have a tire shop look at it and determine if a bolt has come loose and allowed it to slip.
SOURCE: I have a 1997 Ford
Yes loosening the top strut/bracket is needed to adjust the alignment, the rear should be fine unless there is damage to rear suspension compontents that need replaced, however for that vehicle just the front.
Testimonial: "thank you for your help"
have someone drive it while you listen from outside the car. this could be achieved in a parking lot. it could be an inner fender touching your tire when you get up to speed due to air hitting it.
