For some reason when the water gets filled even for that matter in low level the wash tub literally touches the ground level. Operations is not a problem at all, just that the drum goes down when water is filled.
SOURCE: Washer won't stop filling with water.
slick, first see if the hose came off the pressure switch. Just grab the end caps on each end of the control panel and pull them off, they snap on. Remove the two consol screws, pull foward and flip the consol up. See if the hose came off. If it did, just put it back on and use a zip tie to secure it. See attached photo. Catriver...post back.
SOURCE: washing machine
what kind of washer and model # ? Sounds like.. You have a bad pressure switch or the small hose connecting to the pressure switch may be bad or the connection on the switch or tub is linking air pressure I seen where mice had chewed holes in them
SOURCE: GE frontload washer will not wash cycle or spin out
Thanks to Guest #2 our laundry is back in action and we're not waiting for a serviceperson. We took the front panel off, unscrewed the white plug and was sure our plastic drawer was open to catch the water, a load's worth. We found a small screw driver, 8 or so pony holders, some change, drill bits, bark, games pieces, can tops, etc... unbelievable. Thanks SO MUCH for the hint!
SOURCE: Kenmore 90 series washing machine
Follow all jsrocks tests,
but Before replacing the pressure switch there are more tests of function
Blow any water out of the air tube, it should be empty when the washer is empty, water remaining in the tube messes up the pressure sensing(usually makes water level lower so doubt this is the fault)
Kenmore pressure switches are adjustable, the adjustment is hidden.
An internal spring stretches over time and does not react properly.
to test whether just the adjustment is required,
SOURCE: lg wm2277h has low water level
The water level is very low on front load machines. (Below the bottom of the door) While the washer is running, push and hold the "spin speed" and "soil level" buttons at the time. Display should be between 230 and 255.(normal) If you do this while the machine is filling, you will see the numbers change. This machine only uses about 12 gallons of water for an entire cycle, vs. about 45 for some top loading machines. THIS IS NORMAL ! The machine will adjust the amount of water based on the type and volume of clothes in your washer. On a large load, you will see wet clothes, but no water sloshing around. PS. Because the machine uses so little water, make sure you use only one tablespoon of HE detergent (and only one teaspoon of fabric softner if you use it). This is very important.
If this info was helpful, please rate it as a "FixYa". Thanks.
