Question about Acer Aspire 5050-3242 Notebook
Fail to boot
Stay to status white screen
Which part is failed on my iMac with white screen?
Did you read the Apple support page on this problem? they are really good in helping: Troubleshooting My computer won turn on
Nov 25, 2014 | Apple Imac Alum. 20" 2.4ghz Intel Core 2...
Phone stays on white htc startup screen. have tried removing battery and sim card and restarting
Try toggling the volume bar on the right during boot to see if you get the option for a hard reset. If that fails, you might try letting it run dead at that white screen...probably will take days...then try charging and rebooting. I had an IPOD that resolved by doing that.
Aug 25, 2011 | HTC 7 Surround Cell Phone
When I started my DELL Inspiron 1525 running Win 7 Ultimate, I got a white-on-black screen which questioned the voltage from power adapter. Diagnostic program run.. Stopped with the following msg: Error...
2000-0142 and 2000-0146 are hard drive SMART errors, indicating the HDD will fail.
To boot message about the AC adapter was a BIOS level message that normally appears when a Auto/air ac adapter or other 65 watt ac adapter is used to power the system.
Jul 16, 2011 | Dell Inspiron 1525 Laptop
My BB pearl won`t turn on, first the screen went white
You can re-charge your battery fully by the provide electrical charger for 6 hr , then you can try and send me status.
Jul 22, 2010 | RIM BlackBerry Pearl 8100
A well meaning~idiot teenager changed my set up on my Dell Dimension in BIOS to Intell ARRAY.. now I cannot bring Windows up
If the well meaning teenager took a non-raid configuration and created a RAID array, then any data on the drives was destroyed.
If you reply with the RAID array and HDD status information from the boot screen (THE intel Raid Controller will report the status of the array, degraded, normal or Failed and the status of each HDD member or non-member disk.) With that information I MAY be able to assist in getting the system to boot
Mar 01, 2010 | Dell Dimension E510 Dual Core 2.8 Ghz...
No normal boot up, screen stays greyish white with lines.
if its booting up and yopu are not able to see the line then its most probably the display problem you better contact service centre bfore trying anything or use a external display to check its running
Aug 03, 2009 | HP Pavilion dv6000z Notebook
Same thing
The white screen could indicate a bad inverter or the screen itself.The screen staying black could mean the video card has gone out.
Jul 28, 2009 | Acer Aspire 5670 Notebook
When PS3 boots the screen turns green with white dots
Emergency cooling should be cleaned. If not cleaned, you risk expensive repair.
Oct 24, 2017 | Sony Playstation 3 (PS3) Console
Computer will not boot.
Form the info you provided, you have a RAID (Redundant Array of Independent Disks) disk array. RAID 0 (striped disks) distributes data across several disks in a way that gives improved speed and full capacity, but all data on all disks will be lost if any one disk fails. Apparently Diagnostics has determined that “Drive 2” is defective. You will have to replace the defective hard drive and reload the Windows operating system.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 21, 2008 | Computers & Internet
Acer Aspire 5050-3242 Notebook Logo
22 people viewed this question
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
