Question about EliteGroup P6IWP-Fe Motherboard
Suitable replacement motherboard
I need to replace the mobo on my machine.
It has an Elitegroup P6IWP-FE Socket 370 with either i810 or i810e, can't remember if it was the e chipset or not.
I don't want to reinstall windows, so I was hoping to run the gambit and try to let windows redetect a new mobo and hope it takes it.
Problem is, I've been having a hard time to find a replacement for that particular motherboard that would do the trick.
Any suggestions on a course of action?
It's a much needed machine, and to start from scratch would be a very difficult thing to do at this point.
I also know that my other option is to slave the HD and salvage everything on it, on a new system as a sort of compromise.
  • Radre Oct 29, 2007
    It may yet be a CPU problem, as it seems that the board is recieving power, but will not power on, otherwise could be a PSU problem as well.
    I've eliminated all but the Mobo and CPU+Fan, though, the original wattage of the PSU may no longer be sufficient in delivering enough power, odd as that may be, which is another possibility.
    Thanks for the offer of help though.
    Did I also mention that this old work machine is using the 'horrid' Millenium Edition.
    For some reason it just seemed to have worked well, so we kept it on.
    Taking it to a shop I know of to get a better diagnosis, since I don't have any spares to check those parts for fault.
    Scholar:
  • 119 Answers
Howzit
Okay, the problem here is that there is no guarantees when hottswaping motherboards. First It helps if the mboard your swap to is of the same manufacturer thus this eliminates some driver identification problems with XP. Second the socket set (as you said PGA370) must be the same. Then VGA setup must be the similar as in, if its onboard on the first mboard it must be onboard for the second mboard. Otherwise you should be fine. Another option that you did not mention is creating a second partition on the harddrive and installing XP with any other motherboard onto that pertition you created. That way you can just simply copy you information across when you are running with your new mboard (this may be your best option) . Let me know how you go. Thanks
Regards
Posted on Jan 31, 2008
Supports processors
go to this webpage
http://www.ecs.com.tw/ECSWebSite/Product/ProductArchive.aspx?CategoryID=1&MenuID=24&LanID=0
Identify your m/b - there is a ver 1 and a version 2 of the P6IWP-Fe. near the bottom of the linked page, which seem to blank, there some tabs; click the one labeled CPU. The list of supported CPUs will appear below (scroll down to see them) with the earliest BIOS version to support the CPU in the RH column.
May 30, 2014 | EliteGroup P6IWP-Fe Motherboard
P6iwp-fe max processor support ram max support
Intel PentiumIII, 512mb RAM max. an old board!
Jan 11, 2011 | EliteGroup P6IWP-Fe Motherboard
I HAVE CHANGED MY PROCESSOR 600MHz TO 933MHz. NOW I HAVE A PROBLEM THAT MY COMPUTER IS HANGED AFTER 3 OR 5 SECONDS. MY CPU MANFUCTURED BY GATEWAY INTEL CHIPSET 810.
Is your motherboard support that kind of processor?
Do you run it with the previous installation with the old processor, which is in the harddrive? Its best for clear installed so that all settings are configured to your new setup. Your new setup remembers the old processor.
Sometimes setting the bios to default and reconfiguring it once again solve the problems.
Apr 13, 2009 | Gateway INTEL i810 P3 SOCKET 370 BRYANT...
Upgreid bios i810
I refused to deal with this problems
Thank you for your attention
               Vladimir
Mar 27, 2009 | Intel Computers & Internet
P6IWP-Fe power up problem
Try to change RAM first..if not worked then the processor ...
Dec 09, 2008 | EliteGroup P6IWP-Fe Motherboard
Un install xp
If you are planning to install windowsxp on it. there is no problem about the drivers because you can download the driver here: http://support.asus.com/download/download.aspx?SLanguage=en-us
YOu need:
selet the product: motherboard
select the series: socket 370
model no. : see your model number. in the mboard.
Jan 16, 2008 | Intel ASUS MEW-AV i810 Socket 370 microATX...
Cambio de procesador
may be you write this in global language (ENGLISH) that we can understand the problem and help you out.
Nov 30, 2007 | Intel ASUS MEW-AV i810 Socket 370 microATX...
Motherboard manual
There's two versions of your motherboard listed version 1.0a and version 2.0 i've listed the links for updated software, drivers, bios and manuals for both, though version 1.0a doesn't have a listing for a downloadable manual it has all the other bits and pieces, i've also listed the link to help you identify which version your mainboard is:
software,drivers,bios etc, ver 1.0a:
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=95&DetailName=New&DetailDesc=&CategoryID=1&MenuID=6&LanID=0
software,drivers,bios, manuals ver 2.0:
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=210&DetailName=New&DetailDesc=&CategoryID=1&MenuID=6&LanID=0
version ID help:
http://www.ecs.com.tw/extra/productinfo/MB.htm#ver_mb
Hope this helps you out
Nov 01, 2007 | EliteGroup P6IWP-Fe Motherboard
EliteGroup P6IWP-Fe Motherboard Logo
108 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
